sway bar?
does anybody know were i can get a factory style front sway bar kit? the kit i got from Brothers does not work my spindles hit the end links. i need the factory type. thanks
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: sway bar?
Go to a wrecker and get a 1 1/4inch form any 1973-1987 Heavy Duty 3/4 ton or any 1 ton truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: sway bar?
thanks for the replies.thanks shady looks like i will have to go with ECE even though i have had problems with their parts before.
Re: sway bar?
Re: sway bar?
i would try the 73-87 idea but there are no junk yards here,thanks
Re: sway bar?
CPP also sells them. I have their rear sway bay. Install was easy and its a good quality item.
72 C10 lwb fleetside -stock 350/350 combo |
#7 | |
Re: sway bar?
![]() Matt |
![]() Join Date: Dec 2013
Re: sway bar?
Use the heavy FACTORY bar there easy to find the bolt holes are already drilled in the frame and a arms and don't use urethane bushings unless you want to hear them squeak and moan all the time . Why buy aftermarket when the stock system has proven itself to work great ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Oct 2010
Re: sway bar?
What spindles are you running. I'm using this bar and haven't had any issues.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Re: sway bar?
not sure what spindles are on the truck i bought it that way.the way the Brothers sway bar is mounted is on the front of the lower control arm with a L bracket.just weird,i am looking into the used factory style set up for sure.
