Old 03-18-2016, 05:07 PM   #1
craigg1
LS Motor Mounts
Fixing to do a 6.0 swap in a 68 C10 and have been looking at different motor mount options but really can't decide. Which mounts require no welding and also keeps you from having to notch the frame? I will also be putting in the 4l80e transmission and using as much A/C components from the donor truck as possible, so trying to decide which motor mount will work out the best for my needs. Needing advice.. Thanks.
craigg1 is offline   Reply With Quote
Old 03-18-2016, 11:21 PM   #2
chevy72blu
chevy72blu's Avatar
Re: LS Motor Mounts
I used the CPP mount perches and Holley swap motor mount plates. The CPP perches didnt match my bolt holes, but all it took was drilling a few holes. I was able to use the stock transmission x member just by moving it back a bit. You'll need to shorten your driveshaft.
No welding or notching required.
For the accessories, it depends on what year the donor was from. Mine was an LS1 fbody and everything cleared by the compressor (a notch would have been required). I plan on going with one of the aftermarket top mount AC brackets when I add AC back to the truck. These guys have what you need http://www.dirtydingo.com/shop/index.php
You'll have more luck in the LS forum.
Good luck and post pics!
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 03-19-2016, 12:28 AM   #3
craigg1
Re: LS Motor Mounts
My donor is from a 2004 GMC Sierra 2500
