![]() Join Date: Oct 2015
Porterbuilt c notch question
I was installing my c notch yesterday and the spring bolt hole or airbag stud hole in the notch doesnt line up completely with the frame?
Should I enlarge the hole in the notch or the frame? It's the hole not circled on the bottom of the frame. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Porterbuilt c notch question
I would enlarge the hole in the frame.
Make sure you have the c-notch pulled up tight to the frame in all directions prior to drilling holes, for accurate placement. A few c-clamps will help.
Yes I did! I lined it all up and even tried to move the upper piece to get the bottom to line up with no luck.
