03-21-2016, 12:06 AM | #1 |
Replace rear shock crossmember?
I'm installing c-notches right now and removed the shock crossmember to make it easier to work in the area. I'm debating whether to use it (it's in great condition) or install something tubular. I'm moving the shocks so I don't care about mounting them to this crossmember, but I'm also mounting bags to the frame and the bag fittings will be run through a hole in the frame, so clearance for that is a concern.
1968 LWB C20 / AC / Wood Bed |
03-21-2016, 06:28 PM | #2 |
Re: Replace rear shock crossmember?
Any thoughts? As I've researched this, I see people (including Hotchkis) adding gussets to the top of the stock shock crossmember. I'm kinda leaning toward reinstalling it now since the c-notch doesn't want to line up quite right without the added thickness below the frame, but since I have the C-20 frame stiffeners I'll need longer bolts to do the install and am still not sure how the airbag install would turn out.
03-21-2016, 10:30 PM | #3 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
If the air bag kit was designed for 67-72 frames, the stock crossmember shouldnt be in the way of anything...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
03-22-2016, 12:40 AM | #4 |
It's not a kit, just some bags and 90* fittings... I'm not using upper cups like I've seen elsewhere, so the fitting will be poking through the frame and x-member support.
03-22-2016, 01:18 AM | #5 |
I see...If your relocating your shocks then a tubular aftermarket or modified stock crossmember should be ok as long as a gusset is used to support the tube connection from the either upper or lower (depending where you locate the tube x-member) "C" portion of the frame rail. Most c-notched trucks will never see loads and frame twisting stresses that constitute full blown frame rail integrity...
03-22-2016, 05:55 AM | #6 | |
Old member
Look at the 'NO LIMIT" shock relocator kit. It is a nice kit and helps with rear body roll as well since they are mounted outside the frame rails. A good fab person could easly do this them selves. The link is to the kit. http://67-72chevytrucks.com/vboard/s...d.php?t=477839
03-22-2016, 11:13 AM | #7 | |
Anyone know the stiffness of the stock x-member vs a tubular replacement by chance?
03-22-2016, 01:58 PM | #8 |
Old member
Just leave it off. all it is is a mounting bracket for the shocks it doesn't add anything to the frame.
03-22-2016, 04:03 PM | #9 | |
attached Now, I'm thinking maybe I can chuck that crossmember and use a welder series sway bar as pictured, but going through the frame while adding some boxing in the area as well. Then I can also tie in some diagonal tubing between the sway bar outer tube and the frame, similar to the pictured cross-bracing. You can see more details in the guy's build thread here http://67-72chevytrucks.com/vboard/s...d.php?t=534956 But his panhard bar placement is suspect so I'm not sure if the placement of his bracing is optimal.
03-22-2016, 08:30 PM | #10 |
Old member
If your going to use it to brace off of then yes it will be very strong. It will add more strength as you add more bracing but in the normal use it's not much bracing at all other than for the shocks. That's all I was trying to say before.
