Old 03-21-2016, 07:59 AM   #1
30 a truck
30 a truck's Avatar
vent window rubber
Do you have to remove the top 2 rivets to replace the vent window rubber or can it be cut & 'wrapped" around the frame at the top? I did a search & did not find a answer.
Thanks, Lynn
30 a truck is offline   Reply With Quote
Old 03-21-2016, 10:29 AM   #2
trkfrk
trkfrk's Avatar
Re: vent window rubber
Yes, you will need to remove the top rivets to spread it apart from the frame. I found out using silicone spray it helps get the new rubber in the grooves easier.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
