03-21-2016, 03:14 PM | #1 |
250 Six to 327 Flywheel question
1971 C10 Stepside
Keeping the three speed (Column Shift) had a 250 Six, installing a 327 also going to 20 Inch wheels keeping the 12 bolt Posi. Question should I go to the 12 inch clutch? Question (2) will the same flywheel work? Thank You in Advance. |
03-21-2016, 04:01 PM | #2 |
Re: 250 Six to 327 Flywheel question
I did it years ago, every thing interchanged my was a 250 to a 283 the fly wheel bolt circle are the same and are all internal balance.
03-21-2016, 08:54 PM | #3 |
It is probably not drilled for the 12" clutch though. And the 10.5" should be more than enough.
