03-26-2016, 04:03 PM | #1 |
What's the difference between th400 and th350?
I have a 1970 C10 long bed and the previous owner installed a Turbo 400 to 350 engine. Are there any big differences between the turbo 350 and Turbo 400? Is the 400 just stronger and rated for more horsepower? Or is there a difference in gearing and the way the shift wheels?
03-26-2016, 07:06 PM | #2 |
Re: What's the difference between th400 and th350?
Yes - all of the above.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-26-2016, 08:38 PM | #3 |
Th350 has a detent cable to the throttle on carb and T400 has an electric one to a switch on throttle petal in cab
-Cody |
03-26-2016, 08:40 PM | #4 |
BlahBlahBlah
TH 400 eats up more of your horses
03-26-2016, 08:52 PM | #5 |
I'm kindof a rookie still to hot rodding and restoration. How is the gearing and shifting different? Is one more suited to a weekend driven go fast truck?
I'm starting to make sense of the PO's choices in parts that he put on this truck. He used it to tow a trailer to the track with a matching 1970 c10 on it, that one was a 10 second wheelie truck though. I have some other projects that come before the tranny, but my long term plan is to buy a gear vendor overdrive, and no sense bolting that up to a tranny I don't want. I'll need to learn more but so far I don't think I'd bolt a gear vendor up to my current trans |
03-26-2016, 09:11 PM | #6 | |
TH350 1st) 2.52 2nd) 1.52 3rd) 1.00 TH400 1st) 2.48 2nd) 1.48 3rd) 1.00 The TH400 is way beefier than a TH350. It was the trans that went behind big blocks and is virtually bullet proof unless your making big power. |
03-26-2016, 09:39 PM | #7 |
Th50
03-26-2016, 09:43 PM | #8 |
03-27-2016, 01:01 AM | #9 |
This is interesting. I had a buddy with a 66 el Camino, 327/350 and I always remember the way that thing shifted. I'm definitely not a tranny expert, so I don't really know how much of a difference there is. How much hp do you think the 400 soaks up? If the 400 was behind the big blocks, is it possible it's more suited to towing than a truck built for 1/4 mile speed? I understand the difference isn't THAT extreme and it wouldn't be logical to say either trans could only do one thing well, I'm just wondering if my money is better spent rebuilding the 400 turbo I currently have, or if I should take the opportunity to switch to a 350 turbo
03-27-2016, 01:27 AM | #10 |
Turbo 400 is much beefier than the 350. If you already have a turbo 400 there isn't much use in changing to another non OD trans. Unless you are going to a OD trans the only thing you would give up with a 350 is some strength and some weight. IMHO the 400 is the better of the two and what I plan to run with a gear vendor. The way I see it is a 400 gives you room to grow. They also used the 400 in towing vehicles due to the fact that it was more stout and wouldn't get as hot as the 350 would have under the same load.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E I call it Bruce Banner.. |
03-27-2016, 08:55 AM | #11 |
It's the difference between the two
Th400 - Th350 = Th50
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-27-2016, 09:01 AM | #12 |
BlahBlahBlah
You can google the horse power loss thing, but I seem to remember it takes about 35 more horses to run. Probably no big deal for a street driven truck, especially if you want the heavy duty-ness of the 400 for using your truck like a truck.
03-27-2016, 10:02 AM | #13 |
Matt, keep the 400. It is the heavier trans [in every way] but to change over to the TH350 is kinda crazy unless you HAVE to. You need a different driveshaft and the yoke is different too,look for headaches elsewhere. Just have your freshened up. That way it is a bolt back in and go and not have to worry about changing anything out.
03-27-2016, 10:16 AM | #14 |
All about them Ks
Keep the th400... They are pure beef compared to the 350.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
03-27-2016, 04:05 PM | #15 |
Scrapper 1
Most forget that there is one thing you can add to a th400 that will make you a very happy camper and it will hurt the pocket book for a little at 2500.00 But surly makes up for it in towing gas mileage and pure fun out and about Gear Vender turn that 3 speed into a 6 speed
03-27-2016, 04:15 PM | #16 |
I like the turbo 350. take it to a good tranny shop, they can build it tough
03-27-2016, 09:17 PM | #17 |
Th400 is a much better transmission than the Th350. That being said, there isn't anything wrong with a Th350 behind a cruiser.
The power loss is not going to be a set number. That all depends on how fast you are accelerating the parts. Slower acceleration is going to equal less power loss. I bet for a typical 300-400hp cruiser you would never be able to feel the power loss. Space reasons would be the ONLY reason I would consider a Th350 over a Th400, but I would honestly just make room for it |
03-27-2016, 09:34 PM | #18 | |
Powerglide is 18 Th350 is 35 Th400 is 48 These are rough numbers but pretty close to what I have heard over and over through the years. |
03-29-2016, 01:01 AM | #19 |
Wow, I never would have guessed that a transmission soaks up THAT much horsepower. What a bummer
03-29-2016, 08:57 AM | #20 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
If you already have the 400THM, thats the one you want. The 350THM weighs 15 lbs less and is geared slightly lower. The 400THM has more rotating mass than the 350THM which translates into a few extra pony's used to turn them. A properly built 350THM will indeed out run a 400THM for the same reasons a Powerglide will out run a 350THM. The bottom line is, in factory form the 400THM is designed to handle more torque and more HP than the 350THM is. Again, keep the 400THM because you already have it. I recently tooled up and learned how to rebuild 350 Turbo's because I have four of them, one in a 408 big block 72 C-10 drag truck, another in a 72 C-10 daily driver/ tow truck. So far I've only managed to break one and that was under no load in the tow truck with no trailer? And that was after 2 years and 10,000 miles of towing 9000 lbs all over the country...~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
