Old 03-26-2016, 07:46 PM   #1
GMCdriver
Wheel/tire question for 1971 GMC
I have a chance to buy a set of used Torque Thrust II's for my truck. They are 505's (2 piece I think?) 15x8 with 3.75" offset. My truck is stock height. My question is will these work and what would be the best size tire? I am thinking 255 70 15's for the tires all the way around. I am new to this and want to make sure these wheels will work. Thanks!
GMCdriver is offline   Reply With Quote
Old 03-27-2016, 01:17 PM   #2
GMCdriver
Re: Wheel/tire question for 1971 GMC
Here is a pic. 1971 GMC swb, 350, 3 speed column shift, 100% stock original except for a new steering wheel. Still wondering about the 15x8 torque thrusts. Anyone?? Thanks
Old 03-27-2016, 01:30 PM   #3
GMCdriver
I'll try to post some more pics when I get home later today.
Old 03-28-2016, 12:17 AM   #4
GMCdriver
After 2 days of searching the forum and reading as much as I could about wheels, backspacing, offset, etc., I think the wheels that I am looking at will work. They have 4.25" backspace and with 275/60/15's or 255/60/15's, should clear everything with no problems. If I'm wrong, someone please correct me! Here's a couple of my driving project. One as it is now, and one from the day I brought it home.
Old 03-28-2016, 12:22 AM   #5
GMCdriver
Picture from today.
Old 03-28-2016, 04:54 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
4" backspace is usually the max on a 5" wheel before you have rubbing issues up front.
Are you sure of the backspace numbers?
Keith
Convert to disc brakes.
Old 03-28-2016, 08:14 AM   #7
68Stepbed
68Stepbed's Avatar
That's the same backspacing as my old AR Hopsters. Yes, they will work great stock height or lowered.
This pic is only lowered 1" front 2" rear.
same wheels, lowered 3.5/5
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-28-2016, 09:12 AM   #8
GMCdriver
I am not 100% sure of the 4.25 backspace. He said they were 3.75 offset. He may mean backspace instead of backspace. I am supposed to talk to the guy afterwhile. This has been an eye opener for me! So much for just picking out wheels and tires and calling it good!
Old 03-28-2016, 12:58 PM   #9
68Stepbed
68Stepbed's Avatar
Standard backspacing on most aftermarket 15x8 wheels is 3.75". Many people get offset and backspacing mixed up
Matt
Old 03-28-2016, 01:09 PM   #10
GMCdriver
I called him and he said the offset is 3.75, but I bet he is meaning the backspace. I am going to check them out and pick them up in a couple of days. Thanks
