03-26-2016, 09:08 PM | #1 |
Quick disconnect, quick question?
I am hooking up my new fuel system for 5.3 LS in my
53 pickup. I am using the corvette style filter regulator with quick disconnects on all three lines. The fittings that came with the filter kit included the two female ( 5/16 and 3/8 ) and one male 3/8 fitting. while the two female fittings slid on and locked with a high degree of confidence, the male slides into the filter regulator much easier, and has about 1/4 inch of free play in and out after passing the clips that hold it in. It also does not have the internal plastic lock collars like the other ends use. Just metal spring clip type fingers internally. It won't pull out past the clips, but it has more free play than I expected. Is that normal? The other fittings have very little free play after they click in. Thanks
53 Chevy Pickup |
03-26-2016, 10:45 PM | #2 |
Post Whore
Re: Quick disconnect, quick question?
Mine did about the same thing but it doesn't leak.not sure if its normal.
03-27-2016, 07:15 AM | #3 |
Well,
I guess I'll wait and call technical support at Russell on Monday. I think I'll make an adapter to my air tank and put about 80 PSI to the fuel line to pressure check it. I'll see what they say about pressure checking too. Thanks
53 Chevy Pickup |
03-27-2016, 11:23 AM | #4 |
It's normal, mine is the same way and doesn't leak a drop. The line seals on the o-rings inside, so it doesn't really matter where it's at, as long as the ridge is behind the retainers so it doesn't get pushed out.
03-28-2016, 12:46 AM | #5 |
x3
no leaks weird but it works
'68 C10 SWB '85 K30 Blazer |
03-28-2016, 06:52 AM | #6 |
Thanks everyone
back together it goes!
53 Chevy Pickup |
