Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-27-2016, 03:59 AM   #1
BigDan3131
BigDan3131's Avatar
10 Bolt Upgrades
After just looking up a new 12 bolt for my S10 I'm thinking maybe just doing upgrades like stronger axles and the Ultimate cover. The F Body guys are saying the stock S10 10 bolts can handle 350-400HP without sticky tires and using the Ultimate cover with studs, would adding aftermarket axles improve it to 550-600HP without sticky tires?
Should I just have a 8.5 10 bolt narrowed since the 4x4 version is so wide [S10 4X4]. I'm not going drag racing but the thought of having a stock looking S10 with a turbo/4.8L LSx intrigues me.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-27-2016, 02:59 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 10 Bolt Upgrades
Well I have done it every way you can do it . If you are lucky enough to to find a factory 8.5 2wd they work good . Weld the tubes to the housing . they have G body ends so c clip elms are easy to get and 30 spline and a 8.6 gear .
9 inch ford .......easy to build cheap if you do your homework .
I even did the Camaro 28 spline posi and aftermarket shafts in a 7.625 later model factory rear . I seemed to lose the pinion bearings on the small axle . I will never build another 7.5
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-27-2016, 08:44 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
All I can offer is remember, only a rich man can afford to buy cheap parts. .....
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-27-2016, 08:54 PM   #4
RUN GMC
RUN GMC's Avatar
Now the "Ford Explorer rearend swap" is the best thing for the S-10 now you gain 3.73,handles more HP and also get rear disc brake upgrade...............check it out...........
https://www.google.com/webhp?sourcei...end%20in%20s10
RUN GMC is offline   Reply With Quote
Old 03-28-2016, 05:35 PM   #5
BigDan3131
BigDan3131's Avatar
I was driving behind a jeep something or other late model and do they have dana 44's in them? it wasn't the Patriot or the other junk models but the bigger 4 door versions. We had one at the shop once and remember the axle shafts being quite thick.
Old 03-29-2016, 07:01 AM   #6
djracer
djracer's Avatar
9 inch ford with 35 spline axles and a spool. Their is a guy on ebay that is reall reasonable and gives great service.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-04-2016, 09:02 PM   #7
killerpanel
A buddy of mine has an 8.5 in his S10 blazer. Runs a Moser 35 spline spool and their axles. Has 640hp (without nitrous) 421 small block. Runs 10.20's off the bottle, with a tranny brake. 3 years now.
killerpanel is offline   Reply With Quote
Old 06-30-2016, 10:54 AM   #8
whitedog76
Just FYI, yhe V8 powered Trailblazers/Envoys have an 8.6 rearend, along with some versions of the Colorado/Canyon. They may be a little wide for your app. It's worth taking a tape measure to junkyard. BTW, they're 6 lug axles.
whitedog76 is offline   Reply With Quote
Old 06-30-2016, 11:04 AM   #9
Warrens69GMC
Warrens69GMC's Avatar
Quick performance
http://www.quickperformance.com/9-Fo...04_p_4027.html
Old 07-01-2016, 12:01 AM   #10
Captainfab
60-66 Nut
To my knowledge, the Trailblazer SS's all have 9.5" 14 bolt differentials. I believe those are the only Trailblazers with V8's.
Old 07-07-2016, 11:52 AM   #11
whitedog76
The 5.3 TRailblazer/Envoys ALL had an 8.6 rearend. Pretty much all the 4.2 powered ones were the 8", which is still a good rearend. Some EXT models had the 8.6 also. The 8" is a small step up from the 7.5/7.6. It has quite a bit more meat around the center section. I suspect it uses the same 28 spline shafts as the 7.5/7.6.
The only posis for the 8" are the oem G80 and the Eaton/Detroit Truetrac.
Old 07-07-2016, 12:34 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
We've blown at least (7) 10-bolts behind our WS6. At around 350hp, a stock 10bolt frowns. You can use the girdle/brace for the housing which will help the external strength, but it will only do so much. The case itself is actually sorta weak.
We have a large girdle/brace for the f-body 10bolts (has the bracket fit for the fbody) if youre looking for one. I'll have to double check which brand. (T/A or AAM I think). Its brand new.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-07-2016, 11:35 PM   #13
Captainfab
60-66 Nut
I stand corrected. I did not realize that some Trailblazers/Envoy's were available with the 5.3.
Old 07-08-2016, 09:27 AM   #14
FB85C10
i did a 8.5 10 bolt rear in my 1985 c10. i had it narrowed 11.5" and welded the tubes and replaced the 28 spline and upgraded to a 30 spline axle (88-up), i used moser axles, auburn diff. w/ LS and 3.73 richmond gears with the moser rear cover. i was told it could hold up to 600hp. i have not used it yet.
FB85C10 is offline   Reply With Quote
