wiring clean up
Looking for ideas of cleaning up the wires coming from a AAW fuse block under the hood. Would like to see what you have done. Maybe a boot of some type? Your ideas please.
Thanks, Lynn |
Re: wiring clean up
Interested also.
1969 Chevy c20(Miss Hackjob) |
Re: wiring clean up
nobody cleaned it up any??
Re: wiring clean up
How extensive are you talking? Maybe I could give some ideas.
Re: wiring clean up
Something like a boot to make the wires coming from the plugs look better.
Re: wiring clean up
I used some expandable sleeve from Mcmaster carr comes in many sizes and colors heat resistant etc. Ends do fray, can be melted to seal them, but also needs to be folded back on itself or maybe someone has an idea for an end cap. Or wrap.....http://www.mcmaster.com/#standard-ca...eving/=11s9t9k
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Re: wiring clean up
Could see if you could modify a plastic box to cover the plug. Might have to drill holes in the truck for the box to hold onto the firewall then do the wire braid sleeves.
Re: wiring clean up
You could ask Adam "BossHogg69" he posted a pic in one of my threads (another hydro boost vs power disc thread) that shows his engine bay. Looks like he fabbed something to hide it pretty well. Looks really good!
Sorry I don't know how to add a link. Ryan |
Re: wiring clean up
I unplugged mine and removed it from the truck. I removed the black tape from around the wire and I coiled it up and smeared go jo hand cleaner and let it soak in a 12 inch by 12 inch zip lok bag for a few days then pulled it out and wiped it down untill it was clean.
I then put it into another zip lok bage and pumped a few, alot of squirts of armor all in and soaked it good and let it sett for a few days. pilled it out wipped off the armor all and re rapped it with electrical tape. looked brand new some of the electrical connections needed additional clean up attention. |
Re: wiring clean up
Mine is already brand new, AAW. Just not wanting the colored part of the wires to show where they come out of the plugs.
You might look for a late model truck or passenger car air filter box, one that snaps closed so you could contain everything out of sight....just a thought
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
Re: wiring clean up
Try looking up wirecare. Com, they have a spiral wrap
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#13 |
Re: wiring clean up
Please be careful with spiral wrap, especially in situations where electric wiring, air, hydraulic tubing is present and there are formed bends to the wire bundle, tubing. The edges of the spiral wrap can carry a formed load to them and may slowly cut into wiring, tubing. Just sharing from past experience.
My other vehicle is unmanned.... |
#14 | |
Re: wiring clean up
Thanks for the info., I think I know which product you are referring to...
