Old 04-01-2016, 06:29 PM   #1
Fishjeepchevy
5.3 4l60e swap vss what to do
Swapping into an 87 r10 rcsb I have the vss plugged in on the tailshaft of the trans and the harness has a wire labled vss question is what dobi use it for
Fishjeepchevy is offline   Reply With Quote
Old 04-01-2016, 06:41 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 5.3 4l60e swap vss what to do
If it's a single green wire coming from the PCM, then its for your speedometer.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-01-2016, 09:19 PM   #3
truckdude239
truckdude239's Avatar
Which doesnt always work for all speedos i ened up spilcing into the vss sensor for ky gauges
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-01-2016, 10:12 PM   #4
ls1nova71
ls1nova71's Avatar
What are ky gauges? A lot of times splicing into the VSS wire directly will cause interference and send a skewed signal to the PCM and can cause transmission shifting problems.
Old 04-02-2016, 01:59 AM   #5
truckdude239
That was suppose to say my gauges mine seems to be shifting fine im running dophin gauges the vss wire from computer would peg the gauges full over no ammount of programing would make it work i wired i to the vss at the trans and did the speed calibration and it works great
David fuller
2000 Tahoe 5.3l 378
Old 04-02-2016, 03:00 AM   #6
Fishjeepchevy
Thanks guys for the quick reply I also got a complete wiring schematic for my engine and verified
