Old 04-03-2016, 03:58 PM   #1
Nodnarb76
Nodnarb76's Avatar
Radiator fittings for trans cooler lines???
Ran into a problem with my LS swap on my 87 Suburban.
I don't have the correct fittings to attach my transmission cooler lines with 6an connectors to my radiator. Using an Enytopy radiator by the way.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-03-2016, 05:13 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Radiator fittings for trans cooler lines???
You'll have to know what size/threads those bungs are..if you don't know contact them to find out what you need,, would be my suggestion.
Old 04-03-2016, 05:25 PM   #3
qwik
qwik's Avatar
Most are 1/2-20 straight thread, I've used 6an to 1/2-20 flare fittings with an o-ring.
qwik is offline   Reply With Quote
Old 04-04-2016, 10:38 AM   #4
Willie Makeit
Willie Makeit's Avatar
Qwik is correct in that it is straight 1/2"-20 threads but it is also an inverted flare fitting. you'll need something like this to connect it to an AN fitting.
http://www.ebay.com/itm/230894574606...%3AMEBIDX%3AIT
Willie Makeit is offline   Reply With Quote
Old 04-05-2016, 12:34 PM   #5
Hart_Rod
Hart_Rod's Avatar
Whose radiator do you have? Entropy suggest using a 5/16" inverted flare to a 6AN fitting in their radiator.
Hart_Rod is offline   Reply With Quote
Old 04-05-2016, 01:14 PM   #6
roushinator
roushinator's Avatar
Glad to know i was about to order some.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
