Old 09-26-2003, 12:55 AM   #1
GSXMEN
400" 2-bolt Block For Sale
I have a bare .030" over 400" block/caps for sale. This is a 2-bolt block with only the 2 freeze plug bosses. Should only need to deck block and finish hone to fit your pistons.
Block has been magnafluzed - no cracks.
$350 plus shipping (if necessary). I'm in Binghamton, NY 13901
email at: gsxmen@sbcglobal.net
Scott
GSXMEN is offline   Reply With Quote
Old 09-26-2003, 07:49 AM   #2
MOTHERTRUCKERS
Any chance it has 020 or 030 cast in the side?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-26-2003, 11:00 AM   #3
GSXMEN
I'll be checking the #'s later tonight. I'll post them later.
Thanks.
Scott
Old 09-26-2003, 11:17 PM   #4
GSXMEN
Finally got the #'s off the 400 block:
Front Pad: FC222TTC (can't really make out the first T, but I believe all truck blocks start with T)
Rear Deck: 3951509
Date Code: B 15 8
Oil Filter Area: 010, 020, 164 (I'd be curious to know what the 164 stands for)
Bell Housing area: H11, 010 (don't know if that means anything or not)
*Only #'s I didn't copy down are the ones in the timing cover area.
Thanks.
Scott
Old 09-28-2003, 11:07 PM   #5
GSXMEN
Well...checked the block tonight to see if the top bolt hole was drilled/tapped in the bellhousing area - Nope. Looks like that makes it a passenger car block. (Not that that should mean a whole lot).
Still available. Shoot me a PM or email.
Thanks.
Scott
Old 09-29-2003, 08:14 PM   #6
Bowtiefreak
Bowtiefreak's Avatar
That 509 block is one of the better blocks out there and a 2 bolt main is way better than a 4 bolt in the 400 blocks. And if you want to put the splayed caps on there, then they are even stronger.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 09-30-2003, 11:09 PM   #7
GSXMEN
Thanks for the input! In addition to that...this is one of the '2 freeze plug bosses' blocks. Everything I've heard, says that meant less core shift.
**Any one know what the '164' #'s by the oil filter stand for?? I know that the 010 and 020 refer to the nickel and tin content, but I've never heard what the 164 was.
Scott
Old 10-02-2003, 12:07 AM   #8
GSXMEN
ttt
Scott
Old 10-04-2003, 10:50 PM   #9
GSXMEN
Anyone?
Scott
Old 10-10-2003, 11:19 AM   #10
GSXMEN
Back up top.
Scott
Old 10-21-2003, 11:37 PM   #11
GSXMEN
Still available.
Scott
Old 10-31-2003, 02:27 AM   #12
GSXMEN
Just want to bring this back up top.
Anyone in the NY, NJ, PA area that might be interested, I'd be glad to do a little driving to help eliminate shipping costs (depending on how far away).
Scott
Old 01-15-2004, 01:22 AM   #13
GSXMEN
Thought I had this block sold, but the deal went south.
Still for sale. Thanks.
Scott
Old 01-17-2004, 05:31 PM   #14
GSXMEN
Back up top.
Shipping is not a problem. Thanks for looking.
Scott
