04-05-2016, 11:18 AM | #1 |
72 c110 rear disc conversion
Hello I just converted my rear breaks to disc and my rim won't clear the caliper.
72 c10 5 lug I was using a set of keystone,s with 275 60 15 tires. Can anyone recommend a rim that would work that would take those size tires and clear the caliper? Or has anyone done the conversion that might b able to point mee in the right direction? Thanks |
04-05-2016, 12:37 PM | #2 |
Re: 72 c110 rear disc conversion
How close are the rims? Perhaps you can use a thin wheel spacer?guess it depends on just how close they are.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
04-05-2016, 01:49 PM | #3 |
The mounting surface of the wheel is about 1/4"from the factory wheel studs when it hits the caliper.
04-05-2016, 02:56 PM | #4 |
A wheel spacer might be a more cost effective solution. But hey we all love new rims too!
1972 C10 - It might be old, but it's not slow |
04-05-2016, 07:59 PM | #5 |
What did you do for a rear conversion? Looking to do so on my 70
04-06-2016, 06:27 AM | #6 |
Old member
Chevy ralley's should fit.
The wheels what ever you buy cant have a taper. They need to be straight.
04-06-2016, 09:57 AM | #7 |
EBay item 230845329214 rear disc conversion
04-06-2016, 11:27 AM | #8 |
Old member
Looks like the CCP brakes. Have fun with them. The park brake is really fun to get right. I have this kit on mine. After 4 days in the shop working on it I got it to work pretty good. After about a year it works OK.
Not a big fan of them. Checkout the link. http://67-72chevytrucks.com/vboard/s...=572063&page=2
