04-05-2016, 07:27 PM | #1 |
Load Capacity: Tow Hooks
Does anyone know what the load capacity is on the factory tow hooks from 67-72?
04-05-2016, 10:00 PM | #2 |
Born Psycho
Re: Load Capacity: Tow Hooks
not sure on the exact poundage is BUT it's way more than the frame would tolerate-in other words you would rip the frame apart before the hook would break.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-06-2016, 01:03 AM | #3 |
I recall some one peddaling some cast iron look alike junk and selling them for outrageous money. crooked and and unsafe
04-06-2016, 06:16 AM | #4 |
Re: Load Capacity: Tow Hookscast
Someone will know, but comparing to Gemplers forged steel hooks, probably above 9000 lbs per hook. I wonder why the removed thread guy did not offer cast steel instead of the cast iron, as cast steel probably also would have surpassed the frame strength.
Just wondering...
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
04-06-2016, 06:53 AM | #5 | |
I thought the thread removed guy said he destroyed his molds... Hmm?
53 Chevy Pickup |
04-06-2016, 11:14 AM | #6 |
The thread wasn't removed by me, you can thank the admin.
04-06-2016, 11:17 AM | #7 |
I'm having them drop forged reproduced.
And these will rip the frame from right under your seats. |
04-06-2016, 02:35 PM | #8 |
Spent about two hours looking through some GM engineering docs and manuals I have to no avail.
So using simple numbers and accepted practices for winching a rolling load I'm thinking that they need at least a 70,000lb plus load capacity. Taking into the fact the the C30 maxs at 14,000lb gvw and the accepted safety factor of 5:1 that puts us at 70K as a safe low working limit.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-06-2016, 03:41 PM | #9 |
Here is a link of a guy who supposedly designed them for GM.
http://forums.trailvoy.com/showthrea...s/20968?page=1 70K sounds a little high for a 1/2 thru 1 ton but not saying you are wrong. Grade 8 bolts and frame may give before that. Probably if you are a GVW you better hook to both hooks.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 04-06-2016 at 03:48 PM. Reason: words |
04-06-2016, 03:54 PM | #10 | |
04-06-2016, 03:55 PM | #11 | |
04-06-2016, 04:01 PM | #12 | |
04-06-2016, 04:22 PM | #13 |
I don't think you have to register just arrow down to the the thread. But here is the quote.
Tow Hook Strength I used to design tow hooks for GM trucks. Real-life conditions, such as jerking, cold weather, random pull angles, repeated use, etc., make defining a specific load rating impossible. GM does consider things like trailers and helicopters when designing tow hooks, so it's safe to say they will take several thousand pounds in any reasonable pulling direction. http://forums.trailvoy.com/showthrea...s/20968?page=1
04-06-2016, 04:52 PM | #14 |
04-06-2016, 05:03 PM | #15 |
If it were me I would take into account (in the tow hook design) not just the capacity but also what happens to the pieces assuming the tow hook fails.
Assuming 70,000 lbs any loose fragment will be moving away from the fracture at ballistic or at least potentially fatal speeds. I recall reading about a bulldozer trying to pull another bulldozer (that had become stuck) using a chain. One of the workers standing nearby was killed when a link parted. It is in the OSHA reports from around 1972 or so in Southern California. |
04-07-2016, 10:43 AM | #16 | |
I am looking a drop forged now, because I am still a little concerned how well cast steel would hold up in actual usage. Still open to conversation. |
04-07-2016, 01:50 PM | #17 |
Well, there is a pair of eom on ebay for $250 and you actually do not know for sure the abuse or non use they have taken. So I guess the pricing may determine the need. I would think you would have to produce and buy so many for them to make them --drop forged being probably the more expensive than cast steel. As I understand yes drop forged is stronger but depending on the alloy of the cast steel they get closer. Cast steel may bend easier before breaking -- but still exceed the bolts and frame and could be a better thing than an explosive break. Dunno
I would be satisfied with quality cast steel. I worked on crews that had to unstick and pull backhoes and small dozers with digger trucks and stake bodies and you need common sense on where to stand to protect yourself from a winch cable or chain or hook if something gave. If you do not have that sense --- you may easier become a victim.
04-07-2016, 02:29 PM | #18 |
This whole idea of reproducing tow hooks to cash in on the price of originals is just scary at best . Who would be crazy enough to buy reproductions for anything more than $50.00 a set ? I really wonder why anyone would ? The price has risen over the rarety of originals not availability of reproduction look alikes ? Like I said before it reeks like the south end of a north bound BULL ! I say build them , test them , copy right your version , and then spend weeks marketing your reproductions ! Best over insure them on the liability side as I'm sure they would be put to the test just cause . It's all just speculation until the op ponies up his version for approval or dismissal ! In my own personal opinion . We can all wonder if they would look right or tow 10 lbs or 10,000 lbs we'll never know until their produced .
Posted via Mobile Device |
04-07-2016, 02:43 PM | #19 | |
One last thing on your thought about why someone would pay more than $50 a set... For the same reason you pay $12 for a Big Mac (at least that's what it was 10 years ago, most likely more now) value meal in Waikiki, Hawaii McDonalds verses $6 in your local McDonalds, supply and demand. And hey, the beautiful thing about America, no one is forcing you to pay $12, or even $6 for a $1 (production cost) meal, you can still choose to eat somewhere else. |
04-07-2016, 03:21 PM | #20 |
I like the idea of reproduction tow hooks as long as they are strong, I wasn't for them if they are for looks only...good luck and depending on price I may want a set for my 72 K20
04-07-2016, 03:29 PM | #21 | |
Thanks |
04-07-2016, 03:30 PM | #22 | |
you are not able to see the difference? I'll help out then, here is a clue; if a fender, grill, bumper, etc. fails in some way, it is doubtful that that would cause personal injury....
53 Chevy Pickup |
04-07-2016, 03:42 PM | #23 | |
You are going to me more likely to get hurt or killed by a chain or strap breaking than one of these hooks, unless of course the bolts are doing what they are designed to do first, which is break/shear off. |
04-07-2016, 04:21 PM | #24 | |
Maybe it would do a little worse in an accident. Maybe... What's normal use for a tow hook?
53 Chevy Pickup |
04-07-2016, 06:05 PM | #25 |
A tow strap can exert tremendous stress On a hook especially if being yanked from a stuck position. I have personally seen idiots using hitch balls and have them snap off and go flying threw windshields and body panels like butter. A tow hook should be able to handle extreme stress and I'd rather have a non production looking hook that's meant for it than a exact copy not built for use. Most if not all tow hooks are forged Steel and not cast. Forged steel will bend and at least take some energy out of the failure. Cast will snap and become a projectile that could easily kill a person
Tags |
tow hook rating rated |
