Old 04-05-2016, 10:58 PM   #1
GEF56
Front Fender Alignment
56 trying to align front fenders with the cab.
Inner fenders are aligned with radiator support and lower cab brackets per the assembly manual. When I attach the out fender to the inner fender it is not aligning with the cab ( the front of the outer fender is too high.
Any suggestions?
GEF56 is offline   Reply With Quote
Old 04-05-2016, 11:04 PM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Front Fender Alignment
Is the fender high or the hood coming down too low based on where the hinges are at on the cab?
The way I did mine was get the front clip all lined to itself and the cab and hood gap set then I lifted the clip onto the vehicle and chased gaps knowing both units were already lined up to each other took no time at all
Things to also consider are radiator support bushings but if the fender is to high then it couldn't be worn out perhaps incorrect parts used?
Also pics are worth a thousand words
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
