![]() Join Date: May 2014
Fuel gauge problem
I know this item has been addressed a million times, And I've read many of the threads, but is there a way to test the actual gauge with the instrument cluster out of the truck?
I pulled my seat and then removed the sending unit, thinking that was my problem, but I'm getting the 0-90 ohms when I test it, and when I manually operate the float when connected and grounded, I cant get past about 1/3 of a tank on the gauge. I removed the instrument cluster, cleaned every connection, but still won't go past 1/3. I'm thinking the actual gauge might be bad, but not sure how to test it. I have the basic inst cluster with idiot lights, but also have a spare cluster with all gauges. Is there a way to test using the 2nd cluster that I have? Can the fuel gauge be removed from one and put into the other? Everything appears to be properly grounded properly
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
Re: Fuel gauge problem
Yes. A 12V signal through a 90 ohm resistor should read Full, and without the resistor should read Over Full when grounded. When no resistance (0 ohms) it should read empty.
I didn't have a 90 ohm resistor so I used 100, it was close. I would imagine a 45 or 50ohm should read half a tank? For more info on bench-testing them: http://www.modsandrods.tv/2012/03/29...uel-gas-gauge/
Thanks Dave. I checked an old stock of resistors that I had, but none close to 100 ohm. I may order a 100 ohm potentiometer, as suggested in your link. In the meantime, I removed the gas gauge from my spare cluster, but the two gas gauge nuts on rear of mmy original cluster won't budge. They just twist the pc board when I try to losen them
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's a good link by our gauge testing expert.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 04-06-2016 at 01:52 PM. Reason: The link didnt show up. |
Msgt USAF Ret
Here's a link to our gauge testing expert. Tom T-Bone.
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
take a piece of wire and run a temp ground from the sending unit to the body of the truck
Thanks for the info, and that link, Tom. Very informative. I put about 5 gals of gas into my tank, removed the tan wire from the fuse panel and checked with my ohm meter. I got a reading of 34.6 ohm, so about 1/3 of a tank. Re installed the instrument cluster but needle barely moved. Showing a little under 1/4. I also noticed that when I turned on the headlight, I had no lights on the right half of my inst cluster, even though I know all bulbs are good. I think maybe the circuit board could be causing my problems
