Old 04-16-2016, 03:34 PM   #1
azlamm65GMC
'65 GMC Steering column turn signal switch/bearing help please!!!!!
I always try and look through all these forums before I ask any redundant questions but my brother had taken the steering column apart and I always take pictures on my phone or write it down somehow on how any parts come apart. He tore down the column and now I'm trying to piece it all back together. It needed new bearings(upper and lower), have the lower bearing installed but it's this upper bearing that goes with the turn signal switch, through all the info on here and 6066gmc the GMC's and only the '63 Chevy truck have the turn sign Satch and upper bearing are two separate parts. I am using original turn signal switch it's just the bearing I think it needs to go further into the turn signal assembly but it's a little to big. The upper bearing is from classic parts(http://www.classicparts.com/mobile/1.../#.VxKQScg8KnM)
If anyone can just lay it out on how the rest of column and steering wheel comes back together would be awesome.
I'll take pictures
azlamm65GMC is offline   Reply With Quote
Old 04-16-2016, 03:48 PM   #2
azlamm65GMC
Re: '65 GMC Steering column turn signal switch/bearing help please!!!!!
Don't know why but only allowing me to upload one photo at a time
Old 04-16-2016, 03:49 PM   #3
azlamm65GMC
Back side of turn signal switch
Old 04-16-2016, 03:50 PM   #4
azlamm65GMC
I'm not sure exactly where the bearing is suppose to sit at
Old 04-16-2016, 03:51 PM   #5
azlamm65GMC
Bearing from classicparts, comes with spring too
Old 04-16-2016, 03:53 PM   #6
azlamm65GMC
These are all the parts my brother had left together with the column if someone could help out the order. The cancel cam is already on steering wheel along wth the horn contact
Old 04-17-2016, 09:00 AM   #7
duallyjams
duallyjams's Avatar
the bearing goes in after the switch or second on top of the switch, hope that helps.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
