Old 04-17-2016, 07:06 PM   #1
18Z
18Z's Avatar
Backup light switch screws
Anyone have the two screws that hold the backup light switch to the column, I have a tilt on a 71 GMC 4X4.
18Z
18Z is offline   Reply With Quote
Old 04-18-2016, 04:15 PM   #2
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Re: Backup light switch screws
I probably have some from a column I used for parts but they are only short sheet metal screws. As long as they don't hit the shift tube and short sheet metal screw of the correct size should work
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 04-18-2016, 07:32 PM   #3
18Z
18Z's Avatar
Thanks for the reply, that's what I ended up using, I was just trying to keep it original but they work so I will just use them.
Old 04-18-2016, 07:34 PM   #4
dutchmanz
dutchmanz's Avatar
The holes in my column were stripped out so I used a size larger. Glad you got it going.
