Old 04-18-2016, 12:21 PM   #1
whatwhat
Blazer Door Measurement Help
Hey Guys,
Looking to get a measurement for the front door pillar. The truck was completely wasted and was cut apart with a carb saw. My concern is there won't be room for the rockers. Can someone let me know either one of these dimensions? The lower hinge point in relation to the windshield or the upper hinge to the bottom of the door or rocker is question and either dimension in the photo would be most helpful. Please let me know where you are measuring from.
Thank you,
whatwhat is offline   Reply With Quote
Old 04-18-2016, 06:52 PM   #2
69-72
69-72's Avatar
Re: Blazer Door Measurement Help
How about lining the door up with the lower body line to match the bedside. That will pretty much set everything up. You can slip the rocker on then to see if it will fit. You may end up having to split the rocker in half to either add material or take it away to get the bottom gap correct but in the end matching the body line is what needs to happen first imo. From what I can see, the relation of the top of the door to the windshield frame in the corner it looks pretty close to where it should be.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 04-19-2016, 04:30 PM   #3
whatwhat
GMCPaul is out of the bedsides for a while so that is out. I wanted to get the other door mounted but wanted to get close on the measurement.
Old 04-19-2016, 08:07 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
If I am understanding your directions correctly I get 23-3/4" for the left dimension and 23-1/2" for the right dimension.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 04-22-2016, 04:07 PM   #5
whatwhat
Thank you, Looks like I got something to weld this weekend. Just to clarify, are you measuring to the middle of the bolts on the pictures?
Thanks again
Old 04-22-2016, 07:57 PM   #6
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Thanks again
Yes, center to center on the right measurement and top of doorskin at A pillar weld to center on the left one. Pic is where the measurements came from.
DAC
Old 04-22-2016, 09:17 PM   #7
whatwhat
Thanks so much
