04-20-2016, 09:10 PM | #1 |
700R4 shift linkage question
Would someone on here please post me pictures of the correct shift linkage to combine a 700R4 with a 1968 auto power steeringshifter column?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
04-20-2016, 10:38 PM | #2 |
Re: 700R4 shift linkage question
There's no "correct" linkage because it was never offered in our trucks, so whatever you wind up with it'll be custom.
How far off are you with the linkage as-is? Pics? Need more info.
04-21-2016, 08:55 AM | #3 |
I have NOTHING. I bought a auto steering column, but I am replacing my 3 on the tree setup and transmission. Not sure where to begin...
04-21-2016, 09:16 AM | #4 |
Try a Lokar 1801
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-21-2016, 09:34 AM | #5 |
I bought my '71 already converted to a 700r4 trans. The shift linkage seems to be the original configuration and works perfectly. So, I would go that route.
04-21-2016, 09:47 AM | #6 |
Best of luck, setting up a 700R4 isn't an easy task.
1972 C10 - It might be old, but it's not slow |
04-21-2016, 11:22 AM | #7 |
Yep, this. I just got my '72 back on the road after a 700r4 swap, and it was kinda-working with the stock TH350 linkage, but it was sloppy. I used a Lokar 1800 linkage kit and it worked really well. I had to bend it a tiny bit to get it to clear, but now gear selection is really tight and exact.
04-21-2016, 11:45 AM | #8 |
I made my own shifter rod out of a piece of aluminum tubing and threaded both ends (right hand thread and left hand threads for him joints to make a "turnbuckle" for easy adjustments) here is a link to the page I just posted pictures to, see post #9
Ben http://67-72chevytrucks.com/vboard/s...d.php?t=704566
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
04-21-2016, 12:13 PM | #9 |
04-21-2016, 08:34 PM | #10 |
Well,so far to date, the biggest obstacle was the detent cable and the carb pivot point, which I have already done.the neutral safety switch is the next item I'm looking into. Since I used the majority of the factory linkage shouldn't be that bad. We'll see soon enough.
Ben
04-24-2016, 01:33 PM | #11 |
I built what I call the "7" shaft that activates the transmission from 3/8 round stock, then used one of the original 3-tree shifter rods to connect it to the column shift. Required about an hours time, some scrap metal, and a welder.
Butch. |
04-24-2016, 01:36 PM | #12 |
Moderator
Lokar and Kugel Komponents make a linkage kit that will fix you right up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-24-2016, 01:40 PM | #13 |
Looks like I am required to get another column gear indicator. Someone on here had that exact one for sale a while back but I think they were all sold.
04-24-2016, 02:07 PM | #14 |
Moderator
You can get an overdrive indicator from any vendor. The Lokar or kugel linkage will allow you to dial it in so the pointer lines up.
04-24-2016, 05:14 PM | #15 |
well, the Tilt columns have an "OD" lens available from many of the Vendors here, the stock non-tilt columns do not. I made mine from a piece of lexan/plexi glass and took the overdrive lens from a Ididit column indicator set and used some clear RTV to attach it to the plexiglass. works just fine until somebody makes a proper indicator..... How ever, I just bought a Van Tilt column and solved that problem......
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” Last edited by snipescastle2; 04-24-2016 at 05:22 PM. |
06-03-2016, 06:08 PM | #16 |
I just bought a restored tilt column that was rebuilt with NOS parts. I was completely dissatisfied with the non tilt column that I bought for automatic transmission and I am selling it. Now I am going to buy the overdrive indicator that will fit the tilt column.
06-06-2016, 01:08 AM | #17 |
I have the Kugel setup for 700r4. I need the overdrive indicator because nothing lines up. I had to install it b/c the original linkage was in the way of my new hedman headers. The rubber grommet end on the column connection is cheap and is already falling apart but it still works. Super easy to install tho.
06-08-2016, 10:37 AM | #18 |
Unless you buy or have a tilt column, finding an overdrive indicator won't happen.
I had to make one for a non tilt column. I bought an indicator for an "Ididit" Tilt column, took a piece of clear Lexan and traced the original indicator lens pattern onto the Lexan, then cut the new one out, carefully sanded the edges to keep from scratching the plastic. I then took the new "Ididit" indicator lense and placed some clear RTV sealer on the face of the Lexan,and attached the indicator to it. Here are a few pictures of the one I did,just before I bought a van tilt column. Ben
06-08-2016, 11:20 AM | #19 | ||
