Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-23-2016, 03:36 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
91 s15 jimmy hard cranking
my jimmy with 4.3 tbi has just started acting up, it has always cranked right up without giving it any gas, but now i have to hold it about half way down for it to crank and after warming up it runs pretty well normal maybe idles just a hair low. im thinking it might be something simple like a vacuum leak or dirty sensor or something, just wondering if anyone might have any ideas where i should start.
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 04-23-2016, 05:44 PM   #2
wlf89
wlf89's Avatar
Re: 91 s15 jimmy hard cranking
no check engine light btw.
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 04-24-2016, 11:30 AM   #3
BlackedOut67shorty
BlackedOut67shorty's Avatar
How long has it been since the fuel filter has been changed, for vacuum leaks you can try and spray around the intake and around the throttle body base. Another possibility could be the fuel pump getting weak but i dont believe tbi needs alot of pressure. Does it have any sort of miss or feels a bit sluggish since you been having the hard starting issue.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 04-24-2016, 06:32 PM   #4
wlf89
wlf89's Avatar
about first of the year i had to change fuel tank pump and filter, has no other issues other than have to give it gas to start it vs used to would just turn the key and it would crank. what on these engines makes it idle fast when u crank it?, it no longer does that either so what ever causes that could be the culprit maybe?
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 04-24-2016, 06:45 PM   #5
BlackedOut67shorty
What i would do is try to prime your engine about 3 to five times and see if it would start. A fuel pressure gauge would help alot to make sure your at constant pressure. Its seems as if fuel isnt staying pressurized
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-27-2016, 01:19 PM   #6
Cali72K20
Cali72K20's Avatar
Check to see if your fuel pressure regulator is leaking, its on the back side of the throttle body. Rebuild kits are cheap about $25.00 at your local parts store and takes about an hour. The hardest part is overcoming the spring pressure and tightening the screws when replacing the diaphragm.
http://www.autozone.com/fuel-deliver...?checkfit=true
https://www.youtube.com/results?sear...+body+rebuild+
Casey
Cali72K20 is offline   Reply With Quote
