05-05-2016, 06:58 PM | #1 |
70+ ( Old Skool Club )
A/C Compressor Part Question
Poking around under the hood, actually the hood is off so the poking is much easier especially when your 6'2" like me, I noticed the thing on the front of my A/C compressor looks broken to me. I know squat about A/C but it works on y truck and blows cold. Can someone what this is , what it does, and if I need another where I can source it from. Oh yea, it looks like there are three little bolts holding it on and will be easy to remove, or am I dreaming ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-05-2016, 07:06 PM | #2 |
Re: A/C Compressor Part Question
05-05-2016, 07:18 PM | #3 |
Thanks Jim, Looks like more than one part involved. Do you know if the freon empties when you change it ?
05-05-2016, 08:17 PM | #4 |
No loss of refrigerant but it takes special tools to get the clutch and pulley off.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-05-2016, 09:38 PM | #5 |
Thanks..
05-05-2016, 10:27 PM | #6 |
Active Member
I just did the ac clutch on my truck. I rented the puller/installer set from auto zone. and you'll need snap ring pliers too. not very hard to change.
05-06-2016, 05:23 AM | #7 |
Read up in the factory overhaul manual and the factory chassis service manual.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-06-2016, 01:41 PM | #8 |
Old member
The seal behind the nut up inside the compressor is bad to leak. If there is any signs of leaking it's more than likely the seal. Pretty much need the handle that has three lugs to hold the clutch while you take the nut loose then a puller to get the old clutch off.
Do a A6 compressor search it will show you all you need.
05-07-2016, 12:14 AM | #9 |
Thanks all, I appreciate all the help, ideas and comments.
