Old 05-08-2016, 03:56 PM   #1
Skeet J
'53 GMC rear dual wheel axle swap
I'm looking for some help/advise on getting the rear end in my '53 GMC 1 ton swapped out for either a 4.10 or 3.73 gear ratio rear end and maintain the narrow tread width as close to the original as possible. I would like to run 17" wheels and if that's not possible then 16" wheels. I'm not sure if the modern 17" wheels have the same bolt pattern as the old 8 bolts. I need to do some research on that. I have tried a 10 bolt dually rear end from an early 80's I beleive. It is way to wide! I read up on these rear end swaps and found a C&C rear end out of a '98 GM. It was way too narrow and would not fit in due to my frame width and spring mounts. My frame is 36" wide as compared to a modern 34" C&C truck. I have the original dually rear end and have a center section I can swap out to get me the 4.10 gears but getting the 16" or 17" wheels to fit is going to take some more figuring out. Then, I found a 14 bolt out of a '71 3/4 ton single wheel GMC. It has the same spring perch width and bolts right end, but the 16" wheels I have won't quite fit on the hubs. I'm wondering if I need a dually rear end out of a pre '71 GM truck. At any rate I just need narrow and be able to fit 16" or 17" wheels. Anyone been down this path before?
Skeet J is offline   Reply With Quote
Old 06-12-2016, 05:44 PM   #2
mrolds88
Re: '53 GMC rear dual wheel axle swap
Skeet, If I'm right, your truck should have an H072 axle in it. They came in 1 tons til about 70. GM also used a H052 in 3/4 ton truck same vintage. They both used the same center sections. They put 4.10's in the 3/4 tons. Easy swap (other than the weight! LOL)
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
