05-14-2016, 05:32 PM | #1 |
Derale Fan Controller Problem
My dual fans are not turning on. Twin fans on an RnD radiator with Derale fan controller. They have worked fine since installation until a few days ago. I have checked all wiring, including the ground, the inline fuse and every connection. I have bypassed the controller and thermostatic switch by connecting a direct ground to the ground wire coming out of each fan and both fans work with the ignition on. I tried jumping the thermostatic switch with a short wire to connect the circuit through the fan controller and no luck. By this process of elimination I have determined that it must be the switch. Am I wrong? Has anyone ever encountered this problem? I am no wiring guru, but I think I have diagnosed it the right way. Any help appreciated.
Phil |
05-14-2016, 08:02 PM | #2 | |
Re: Derale Fan Controller Problem
05-14-2016, 08:21 PM | #3 | |
05-14-2016, 09:51 PM | #4 |
motor exploder
I had a Derale unit that was dead right out of the box a little over a year ago. It was the 'high amp' dual controller, #16779. Are you using the thread in temp sensor or the push in probe one?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-14-2016, 10:33 PM | #5 |
Thread in sensor. I tried bypassing the sensor and that didn't work. Not sure of the model Derale I have (will check tomorrow), but it came with the radiator and dual fan setup.
05-15-2016, 12:10 AM | #6 | |
05-16-2016, 08:06 AM | #7 |
It's a model 16749. I am going to contact Derale for some "guidance" and see where it goes.
05-16-2016, 09:23 AM | #8 |
motor exploder
Good luck - I hope they are more 'accomodating' to your issues than they were of mine. I also had an issue with the plastic hub/bracing on my Derale fan setup up cracking all the way around. I posted pics of it in the Engine & Drivetrain section.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 05-16-2016 at 09:48 AM. |
05-16-2016, 09:37 AM | #9 |
laying low
This is disturbing to hear. I was just about to purchase a derale controller to use with a GM camaro fan. I surely want it to last more than a 100 miles or so.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-16-2016, 09:50 AM | #10 |
motor exploder
I just installed another #16779 in place of a relay setup that I was using, hopefully this time it works out better. I have 532" of big block that will need cooling in about a month...
05-16-2016, 10:16 AM | #11 |
One thing you need to know is the current draw of you fans. Strat up or surge current is much much higher than continuous running current and can take out your relay or controller. The controller's current capability is available on Derale's website http://derale.com/products/electric-...le-controllers
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
05-17-2016, 10:17 AM | #12 |
Update. Spoke with Eric from Derale within a couple of hours of sending an email describing my issues. He wants me to try one more thing, using the bypass connection to see if it will work. It's currently not wired in. I am not sure what that will show him, but I will get to that and get back to him later in the week. He was helpful, said it might be a bad unit and they will stand behind it if that is the case. I'll update once again when needed.
05-17-2016, 03:21 PM | #13 | |
05-18-2016, 09:44 AM | #14 |
Well, let's see which company fares better. I tried the bypass last night and it did not work. Left a message with Eric at Derale and am waiting to hear back.
05-18-2016, 01:07 PM | #15 |
Called Flexalite today and told the tech guy I was having issues with the controller, he said email him a picture of the receipt and he'd send out a new controller. Done and done, not bad
05-19-2016, 12:22 PM | #16 |
So far, you're the winner. I have called Derale two times and yet no call back. We'll see.
05-19-2016, 03:26 PM | #17 |
Parts and more parts
Frank |
05-19-2016, 03:49 PM | #18 |
The saga continues. Called Derale back and Eric told me to warranty it through RnD. I am fine with that, but thought Derale would do it directly. Shot RnD a note already and heard back quickly. I need to get them my order number. Will do that tomorrow.
05-19-2016, 03:51 PM | #19 | |
Here's another one that is pricey, but no relays. http://www.autocoolguy.com/ Interesting. |
05-24-2016, 02:44 PM | #20 |
Here's another update. RnD followed up with Derale and Derale is to issue a return authorization. I am waiting for that to make its way to me. I am unable to drive my truck until the RA gets issued and then I send the original controller back, as well as wait for the new one to arrive. It might be time to bite the bullet and get something more reliable. This is just frustrating, especially because this one had very limited miles/usage on it. I am not feeling real comfortable with a replacement of the same thing. Anyone ever use one of these? http://www.autocoolguy.com/
05-24-2016, 02:56 PM | #21 |
Flipper58, I've been lurking around your thread a bit. Sorry to hear you are having the problems that you are with your e-fan controller. I too am having fan issues with my Flex-a-lite 295 control system. I chatted with a forum member named gmachinz last year about a possible switch to a system he builds. You might pick his brain a bit as he's pretty darn sharp about electric fans and cooling systems. I'll be hitting him up for a custom system or something of the sort for my needs real soon as well.
Good luck Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
05-24-2016, 03:33 PM | #22 | |
Phil |
05-25-2016, 01:59 PM | #23 |
Good news update. RnD worked it out that Derale is sending me a new controller directly. Hope to have it soon.
05-25-2016, 02:46 PM | #24 | |
Check the draw on 1 fan at a time and then with both going on at once. Here is a link to your spec sheet: http://derale.com/products/electric-...9251222-detail
My Build: 57 Chevy Pro-Street |
05-25-2016, 03:35 PM | #25 | |
