Old 05-19-2016, 08:48 AM   #1
Afirehawk1
66 C10 Shocks
What is the best shock package when using 2.5 drop spindles, stock BBC front coils and 4" drop rear coils? thanks Keith
Afirehawk1 is offline   Reply With Quote
Old 05-19-2016, 10:56 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 66 C10 Shocks
If you only did drop spindles in the front, you can run any stock length shock, since you have not modified the actual suspension travel. Out back you will want to get a shock relocation kit, which will put the angle of the shocks back into the correct angle so they will work as they should. If you're not notching the rear frame, with the relocation kit, you can then run any stock length shock as well.
As for brand, I run Bilstein's on everything I can and love them. Little more money then other brands but it will be the last shock you ever buy.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-19-2016, 11:01 AM   #3
Afirehawk1
Re: 66 C10 Shocks
Can i get more info on the shock relocation kit?
i really don't want to notch or cut the frame.
suggestions?
Old 05-19-2016, 11:14 AM   #4
chevy_mike
chevy_mike's Avatar
Re: 66 C10 Shocks
Early Classic Enterprise make these as does CPP. I can't link the ECE but here is the CPP ones. Basically the same stuff.
http://www.classicperform.com/Store/...ck/6372SRK.htm
Also keep in mind you will likely need an adjustable panhard bar to recenter the axle after lowering it. Without it, the axle will be shifted more to one side and can cause tire rubbing.
Old 05-19-2016, 11:20 AM   #5
Afirehawk1
Re: 66 C10 Shocks
great info, thank you!
Old 05-19-2016, 12:41 PM   #6
Heydon
Heydon's Avatar
Re: 66 C10 Shocks
Thats really useful- thanks.
I have 3 inch lowered rear springs and the tyres do rub on one side. Is there an adjustable panhard bar you recommend?
Lifetime Cal look VW fan on a new Chevy truck shaped adventure....
1965 C10 SWB Fleetside, LT1
1967 VW Bug 2332cc
Heydon is offline   Reply With Quote
Old 05-19-2016, 04:26 PM   #7
chevy_mike
chevy_mike's Avatar
Re: 66 C10 Shocks
I have used both the ECE and CPP versions. Of the two, I like the ECE one better. Both of the ones I used are long versions that go from the frame to a bracket mounted to the trailing arm/axle mounting point. A longer bar induces less side to side movement during up and down travel.
You can get adjustable bars that fit the stock mounts but I haven't used these before.
Old 05-20-2016, 07:10 AM   #8
PGSigns
PGSigns's Avatar
Re: 66 C10 Shocks
I run the Belltech street performance shocks on mine and like them. When I dropped the 66 I used the ECE shock relocator kit and the long panhard bar on the back. Both worked well. The long panhard bar does center the rear up in the truck and also lowers the roll center to improve handling.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
