05-21-2016, 02:43 AM | #1 |
adapt old style valve covers to LS motor
Does anyone know where a guy can find adapters to bolt a early style chevy valve cover to a LS motor valve cover. I am looking to cover the coils with a old valve cover. Any leads.
Vic |
05-21-2016, 07:38 AM | #2 |
Re: adapt old style valve covers to LS motor
hello. if I remember correctly, I some the adapters on ebay.
05-21-2016, 07:45 AM | #3 |
Is this what your looking for? Why would anyone want a LSx engine to look like a SBC? That's like saying, I want my hot wife to look like an ugly woman. I hope not to offend the ugly women out there.
05-21-2016, 08:03 AM | #4 |
Old member
My simple fix was installed some 1/4 x 20 small bolts in the coil brackets and mounted my motor cover should work for valve covers too I would think.
You can see the right side front bolt and lock nut in this picture I have one on the left back side also.
05-21-2016, 12:11 PM | #5 |
Yes dec010974 Those are to replace the factory valve covers and remote locate the coils. I just do not have the room on the frame anywhere to remote the coils. looking to install a set on a LS motor that is in a 32 Ford coupe. Trying to stick with the 60's theme.
Does any one know where to buy a adapter. the adapter nests over the LS valve cover and allows the old style valve cover to cover the coils. Vic |
05-21-2016, 03:25 PM | #6 |
Post Whore
Check pic on post 29..robznob built some nice ones from bbc valve covers.http://67-72chevytrucks.com/vboard/s...=615179&page=2
05-21-2016, 03:30 PM | #7 |
Post Whore
I made these from some scrap alum sheet for mine..so you could fab you a set if needed
05-21-2016, 05:50 PM | #8 |
search on Bay for ICT Billet. they have what you need.
http://www.ebay.com/itm/LS-Valve-Cov...9WzhpW&vxp=mtr |
05-22-2016, 02:05 AM | #9 |
Hey mongocanfly ! Those covers look great. I think that I will look into doing the same for mine.
Vic |
05-22-2016, 10:32 AM | #10 | |
Now for the PCV system!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-22-2016, 12:19 PM | #11 |
Hey solidaxle Those will look cool on that motor ? My problem is I can not remote mount the coils anywhere in my engine conpartment , due to the fact that in my 32 Ford coupe there is no place to put the coils. So I had seen where a guy has just made some type of mounting brackets to accept the old style valve covers over the coils similar like mongocanfly but with small block chevy valve covers
Vic |
05-22-2016, 01:56 PM | #12 |
put them inside on the firewall ??? I have seen big block covers some where but don't remember where though they look funky may be summit racing
05-22-2016, 04:28 PM | #13 |
05-22-2016, 06:29 PM | #14 |
jweb ! Have been in contact with summit and they do not have what I am looking for .
Will keep looking . nsb29 had thought about remoteing the coils and with the size of under the dash there is not a lot of room for them. Thank you guys for the suggestions Vic |
05-22-2016, 06:55 PM | #15 |
You could do the edelbrock coil covers. They look similar to BBC covers. Mine have had the Edelbrock logo shaved off
05-23-2016, 08:36 AM | #16 |
05-23-2016, 02:12 PM | #17 |
Post Whore
On the edelbrock covers you have to use a certain coil from a car..the truck coils won't work..not sure which engine you have.I bought a set and they wouldn't work..so I just made my own.
05-24-2016, 11:04 PM | #18 |
Vic, another option is the Holley coil covers.
Also, depending on the look you are going for, Wegner Automotive in Wisconsin has a valve cover with coil cover combination. They can machine the top however you want...I think. Solid, that cover looks good. Do you have a build thread going on the Corvette? |
05-25-2016, 01:13 AM | #19 |
Good point. I didn't find that out until after I bought them from another member.
05-25-2016, 06:16 PM | #20 |
Here's another option
Amazon.com: TSP LS1/LS6 Fabricated Aluminum Coil... I ordered a set of these, they were really nice but would hit my firewall. So they didn't work for me. If you have the space they're less expensive than the Edelbrocks. |
05-28-2016, 02:22 AM | #21 |
As mentioned that my LS motor is in a 1932 Ford coupe. The engine compartment is real small. That is why I am looking for a retro valve cover adapter to bolt directly to the top of the original LS cover.
Vic |
05-28-2016, 10:39 PM | #22 |
I used the ones from post 8
not sure if this is what you were asking about |
05-28-2016, 11:49 PM | #23 |
05-29-2016, 02:26 AM | #24 |
bpatrol , do those valve covers mount over the ignition coils. If so that is what I am looking for. I am not looking for the adapters that replace the LS valve covers.
Thanks for the help Vic |
05-29-2016, 02:44 AM | #25 |
they do not mount over the ignition coils they replace the ls covers and you remote mount the coils. it really is the cleanest look on the cheap . especially if space is a concern.
if u are simply looking to cover the coils ,holley and edelbrock make a cover as well as ebay variants. but in my opinion they look out of proportion and big. wegner and billet specialties make an all in one cover thats a work of art but it will be well over a grand .....for valve covers..good luck either way phillip |
