Old 05-23-2016, 12:47 PM   #1
1970greenc10
1970greenc10's Avatar
engine codes
Hi, my 03 Silverado 2wd with a 5.3 is throwing codes, U1002,P0725,P3531, and P0455 which I know is a large evap leak. Can anyone tell me what the first 3 codes are for. I tried googling them, but couldn't find anything.
Thanks, Marty
My Chevys
79 caprice classic
70 c/10
69 k/10
03 silverado
1970greenc10 is offline   Reply With Quote
Old 05-23-2016, 01:01 PM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: engine codes
DTC U1001-U1254 = Loss of XXX Communications to PCM
The other two I'm not finding anything if you want I can try to run the vin number in my system (GM) to ensure I have the correct engine and chassis
I would start by checking all of the ground over as well as battery positive
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 05-23-2016, 06:02 PM   #3
1970greenc10
Re: engine codes
The VIN # is 1GCEC14T53Z266959. I'll check the grounds. Is loss of communication a serious problem, because the truck still runs fine I just don't like the check engine light on.
Thanks, Marty
My Chevys
79 caprice classic
70 c/10
69 k/10
03 silverado
Old 05-24-2016, 06:34 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
Re: engine codes
725 is an irrational speed signal
P3531 I'll have to look at work and see since it's manufacturer specific
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-24-2016, 09:16 AM   #5
Valarius_Starchaser
Re: engine codes
P3531 all I'm finding is powertrain code for other vehicles nothing listed for yours very odd
It sounds like the vehicle has some wiring loom being rubbed through that's causing intermittent voltage and "could" put the vehicle in limp mode but as of now it hasen't happened long enough to cause an issue
Maybe 68C15 will find more info or have ideas on it
"Orange Crush"
Old 05-24-2016, 03:42 PM   #6
1970greenc10
Re: engine codes
Update, I was driving this morning, and the check engine light turned off, so when I got home I scanned it again. Now all the codes I listed before are gone, and the only code I'm getting is multiple random misfires. The truck does not appear to be misfiring, it idles smooth as ever, and there doesn't seen to be any loss of power at speed. I still need to check the terminals and grounds and I'll check the harness for damage as well.
Thanks, Marty
My Chevys
79 caprice classic
70 c/10
69 k/10
03 silverado
