fuel filler
I relocated my fuel tank to the rear of the truck, a 1967 c10 2 wheel drive. I don't want to cut a hole in the perfect sheet metal on the side of the bed, I also use the bed to haul stuff and some times have a camper top so I don"t want a bed fill. I wanted to make a copper fill pipe going from the stock fill location.I know I will be punching new holes in the back of the cab, but they wont be seen. Do I need to worry about gas fume build up in such a long tube run.
Thanks for any input.
Never enough time to do it right, always time to do it twice. ![]() |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: fuel filler
You can put it behind the marker light for one. The attached thread has some different ideas for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=368978
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: fuel filler
if you don't mind waiting the half hour or so I takes to fill that monstrosity go for it
#4 | |
Re: fuel filler
No Marker lights on a 67.. |
Tags |
fuel filler |
