Old 05-25-2016, 08:47 PM   #1
YourBuddy'sTruck
YourBuddy'sTruck's Avatar
Helper Springs on C20? Good/Bad Idea?
Hello, Fellas.
I've a 70 C20 that I haul a heavy load with once a week.
It has a FF Axle 14 Bolt Rear End with the 6 Leaf Springs.
My passanger side lists more than the driver's side.
Would Helper Springs be a good or bad idea?
Or, am I just pushing the limit of a C20?
It's a nice "work truck" and it makes me money, so I don't mind spending some on it at all.
Thanks for any advice or suggestions.
Cheers!
YourBuddy'sTruck is offline   Reply With Quote
Old 05-26-2016, 10:24 AM   #2
1970pelle
1970pelle's Avatar
Re: Helper Springs on C20? Good/Bad Idea?
You could go with helper rear air bags. Which would allow you to keep the truck as it sets now, for everyday use. And pump the bags up when needed.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
