#1 | |
'64 GMC 910 Resto-mod
Hi all,
I've been lurking around these forums for a few months, sourcing info on a project I want to start - a 64-67 Chev or GMC 4x4. I was finding a lot of trucks that needed the usual work (cab corners, rockers etc.) My dad found a listing online back home, checked the truck out and picked it up for me. I'm hoping to go back at the end of June/beginning of July to sort some things out, and drive it back. (About 2500 km, or 1500 American moon units). ![]() Full album here It's a '64 GMC 910 (Canadian K10). The previous owner said that it was repainted about 13 years ago, and that the paint is starting to bubble in some spots. It bugged his back to drive it, and he's only owned it a few months. Before that, it sounds like it sat for a year or two. Quote:
My plans for the truck are to (continue to) resto-mod it. I like that the fuel tank relocation has been done (it's huge - 35 imperial gallons...165L if my conversion app is correct). EXTERIOR
Question: I'm not big on the rims. I'd like to eventually go to front discs and at least a 16" rim. I only want to buy rims once, so if I get 16s will they clear discs regardless? ELECTRONICS
MECHANICAL With the big thirsty V8, and a lot of highway driving, I want to do a 5 speed swap. I'm leaning towards the AX15 from a 4.0L cherokee (I know I need an adapter plate, and the jeep driveshaft, for the slip yoke). I had a 92 cherokee years ago, and liked how smooth the engine and trans were. I've found a donor cherokee that I might have before I get the truck, heh. Question: I'd like to go to discs in the front. Does the fact it already have a dana 44 mean I don't have to swap in a whole front end from somewhere else? Also, the transfer case leaked, so someone took and the front driveshaft out, so the truck has been driven as a 2wd. This is also when someone redid the exhaust, so now the T-case doesn't fit back in there. Gonna take it to a muffler shop for that one. INTERIOR
If you guys notice anything else in the photos that looks like it might not be stock, please let me know! I wish I had more photos or info, but for the moment these are the photos and the list of mods from the ad.
'64 GMC 910 |
![]() Join Date: May 2007
Re: '64 GMC 910 Resto-mod
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Very KOOL and nice lookin GMC...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
![]() ![]() Join Date: Jul 2002
Good looking truck. Welcome to the board.
Alright, I know it's been a while bit I'm home and have had a chance to tinker with the truck.
However, I'm having an issue where the truck won't start, and /or won't stay running when it does. My dad drove it about 80 km when he bought it. It started and ran fine. He parked it, then moved it out to take photos and a video, after which it died and it's been tough to start ever since. I had the battery tested when I got home, and it was NFG (dead cell, so it's been replaced). Then it would crank and not catch. I swapped the plugs today, and checked the fuel filter(s). Fuel runs freely. It started right up like it was a new car, and ran for about 10 min then died. I re started it, it ran for maybe a minute, then just...died. While it was running, a multi meter showed 14.6/14.7 volts across the terminal, so the alternator is doing its job. If I let it crank for 3-5 seconds a few times in a row, I can smell gas. My dad and I think it might be a carb float issue, and that somehow it slowly floods while sitting at idle (but not while driving). It's an edelbrock 1406 with electric choke, if that helps. Thoughts?
'64 GMC 910 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If the fuel pump is putting out fuel and pressure, the pressure may be too high. The Edelbrock carbs are extremely sensitive to too much fuel pressure. Edlebrock specifies no more than 5.5 psi. In the past I have set the fuel pressure at 5 psi for an Edlebrock carb. I have read of others setting theirs at 4.5 psi. Yours could very well be flooding out as you said. I would check the fuel pressure. If it is too high, you will need to plumb in a pressure regulator.
there must have been more than leaks to the t/case to take it out and leave it out. they are pretty easy to rebearing and reseal and not that expensive to do
ron |
the PO may have worked at a pulp mill or something similiar where ss is used frequently. amazing how much of it has free written on it, that is unless you get caught at it
r9on |
Alright, so today's adventures in swearing at tools started with checking the distributor cap. Everything looked good, so I was going to check/replace the points.
Then I decided that since I was going to go with an electronic ignition eventually, that time might as well be now. Seeing as I just bought the pertronix coil last night, I stuck with the same company and got their ignition module. Cue at least an hour or two of shimming the magnetic ring, fiddling with the bend of the mounting plate to get the right clearance, shimming the gear end of the shaft, then reinstalling only to find that the distributor sat about an inch out of the mount. After a dinner break and googling, it turns out I put the drive gear on the wrong way. Sorted that out, reinstalled, checked all the wires, and it sprang to life! Let it run, turned it off, and it did the same again. I think now that it was probably a combination of condenser and coil. Now I'm hoping I can plate it up, and drive it a bunch to get a feel for what else it might need. I know for sure it needs tires...and I've decided to go all out and do rims and tires at the same time...stay tuned ![]()
'64 GMC 910 |
New rims and tires. Drove it a bunch yesterday. What a blast!
'64 GMC 910 |
![]() ![]() Join Date: Oct 2011
That's a sweet truck
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
Update - finished my 2000 km roadtrip. Found some electrical issues along the way thread here http://67-72chevytrucks.com/vboard/s....php?p=7645227.
Also found out the hard way that it consumes more oil than I thought. Day 2 of the trip, I was cruising along when I got a top end rattle. Pulled into a rest stop in the middle of nowhere and found there was no oil on the dipstick. A VERY kind trucker gave me a 4l jug and refused payment. I made sure there was no oily sheen to the coolant that night, and the truck doesn't smoke or blow blue so I didn't know where it's going. Crawling around under the truck today there was quite a bit of fresh oil on the bottom of the rear of the engine, so maybe a seal is starting to go. Truck gets a lot of compliments and questions wherever I go. A lot of people think it's a late 50s model...must be the colour.
'64 GMC 910 |
#13 |
check the oil pressure sender . sometimes they leak and oil runs down the back of the engine on the V8 engines . another thing to check is the distributer gasket it could be leaking .
#14 |
So I've been driving the truck for a while now, figuring out its quirks and what modifications/upgrades I'd like to do next.
My big three have been (in no particular order): trans, brakes, and seats. About a week or two ago, the starter packed it in. I managed to get a remanufactured one, and kept the one that came out of my truck so i could have it rebuilt as a spare. Good thing, too, because I spent 5 hours (no joke) trying to get the reman starter in. It's a three bolt starter, with two bolts going in from the nose of the truck, and the top bolt goes in from the transmission side. All three bolts are different lengths. The top bolt will not start in the threads oh the starter, and I'm beginning to think someone just used any old bolt. Is there a set length or specific type of starter bolt? In other news, I picked up the front and rear axles from a 1985/86 Chevy Blazer,as well as the brake master cylinder (the front axle has disc brakes). My truck has leaf springs up front, and the spring 'pads' are the same distance apart as the axle currently on my truck (the only markings i can find on it are '44-5F'. I know it's a Dana 44, with closed knuckles and drum brakes). The distance from the axle flange to the outside edge of the leaf spring 'pad' is within half an inch of my current setup. The shock mounts even look like they'll line up. Long story short, I'm hoping it will be a direct bolt-in, that will mean i can upgrade. However, this has me suspicious that someone either did a lot of fab work, or they swapped the frame. I grabbed the back axle as well, simply so I'd have a matched set. Looks like you can get drum to disc conversion kits from Summit, but that might be something i look into further down the road. Two days after getting the axles, a guy replied to my want ad for seats from a 99-06 chevy/gmc truck. They looked good in the photos (no wear or anything), and when I saw them in person the seller explained he got them from a guy who'd pulled them out shortly after buying the truck, because they bugged his back. Guy I got them from had never used them for the project he bought them for, and there are no nicks or anything - the foam isn't even compressed anywhere. They were an utter steal at $200, so I grabbed them. The only 'disappointment' is that the centre seat back is fixed in place, and there is no under seat storage. Whatever. Even if I have to buy a centre seat for $100 or so, I'm still ahead. I have absolutely no idea what the current seats in my truck are from. I'm thinking some kind of RV or 70s van. Ironically, the centre seat on them is exactly what I want (flip down armrest wroth internal storage, and a compartment under the seat. In keeping with the 'nautical' theme of the truck, the cupholders are wood. I'll take a couple of pics in the next few days. To fit the seats, I think they fabbed up/modified their own frame with a different bolt spacing than stock...fortunately the stock holes seem to have had bolts or plugs put into them, that were then siliconed from the underside. Guess I'm going to have to pull the seats and carpet to figure out what's going on there. How does one go from 'simple' starter repair to considering pulling apart the interior, fitting new seats, and a new front axle?
'64 GMC 910 |
#15 |
Welcome and Beauty truck! I think I saw that rig on kijiji in BC hahaha. Any interior shots?
#16 | |
As requested, interior shots. Does anyone have any idea what these seats might be out of? I'm thinking a van/camper?
'64 GMC 910 |
#17 |
Also, I was out and about the last few days and came across a tow/wrecking yard. They had some older stuff, so I asked if they'd have any kind of parts for my truck...they had two, but one they were parting.
I managed to snag:
...for the grand total of $200. With fall/winter coming, I'm planning on cleaning up and coating the heater housings with POR-15. I'll need to get a new blower motor and cage fan (maybe I can reuse at least the fan from the truck's current econo/thrift heater). I see LMC have new arms and cables for the control box, as well as seals for the heater housings themselves. I don't know if I'll need a new heater core - this one sat, drained, for who knows how long. The hoses were still connected, so I'm not worried about anything having gotten in....just internal rust. And leaks.
'64 GMC 910 |
#18 |
I initially just wanted the mirror mounts off of the doors for a set of West Coast Jr. mirrors I won on Ebay. When the guy told me I could take basically everything I wanted for $200, I figured I might as well take the whole door...
The hood has a few dimples, but is surprisingly in better shape rust-wise than my current one.
'64 GMC 910 |
#19 |
I took the grille off the other day to do the headlight relay mod. The headlight wiring harness isn't exactly in great shape.
Anybody make replacements?
'64 GMC 910 |
