Old 06-03-2016, 09:24 PM   #1
davepl
davepl's Avatar
Weird - Oil ring pops out of groove while running on dyno
A friend of mine ran into a weird problem and I have no good ideas, so thought I’d run it by the board to see if anyone's ever heard of anything similar.
After a rebuild they were running it on the engine dyno and it started smoking badly; it turns out the oil ring had come out of the groove on one piston. Thinking he must have done something wrong during assembly, he ordered new rings to be sure, tore it down, reassembled, and guess what – the exact same thing happened again. In the same cylinder, but with the new rings.
The wrist pin is below the ring pack on this motor, so there’s no support rail and the pin couldn’t hit it from the back (that was my only guess).
The second time he assembled it he put the gap on the thrust side, which he doesn’t like to do, to make sure it would be “held” in place, but it still popped out. Fortunately didn’t damage the cylinder wall either time. I don't know much else about the engine (Big Block Chev or Chrysler RB).
Ever heard of anything like that, or have any random guesses? He's a machinist and a retired Winston Cup engine builder, so there's not a lot he hasn't seen before, but this was new to all of us!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-04-2016, 12:12 AM   #2
swamp rat
swamp rat's Avatar
Re: Weird - Oil ring pops out of groove while running on dyno
I hope he mic's all the bores in all the cylinders or used a boar gauge to check them before assy, then also checked all the pistons with a mic or calipers too? Yea i know if one is off it would probably knock...
Is it possible the oil rings and the width of the piston ring grove are not matching?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-04-2016, 02:02 AM   #3
Bob B.
If the bore mic's out O.K. about all I can think of is the ring expander or the oil groove is miss-machined in the piston.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-04-2016, 01:41 PM   #4
davepl
davepl's Avatar
The bottom rail comes out when it rotates to the pin boss relief. So it's not coming out sideways like there were too much piston-to-bore, it's coming out after the ring rotates a ways and the end reaches the pin boss relief.
He would have checked all the basic clearances, so anything you'd normally mic and check with a bore gauge, etc, I can only assume was checked (I've never seen him skip a step).
Old 06-04-2016, 10:22 PM   #5
swamp rat
swamp rat's Avatar
Well when you figure it out (or even if ya don't) post some pictures..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-05-2016, 02:21 PM   #6
davepl
davepl's Avatar
I'm thinking the piston needs an oil ring support rail but wasn't designed for one, but I need to check more on Monday!
Old 06-05-2016, 03:02 PM   #7
Redline novdog
Redline novdog's Avatar
That's odd. The engine builders credentials are good. I would suspect the piston also. When I build an engine I expect a piston to spec out. Shouldn't have to put each one on the marble table!!!!
Curious!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-05-2016, 05:15 PM   #8
sean1969c10
sean1969c10's Avatar
If the bore is in spec and the clearance between the skirt and bore is right, and it only happens in this one cylinder it stands to reason that something is wrong with the way the oil ring groove was machined into the piston. Very slim chances of getting two ring sets that are bad. Let us know how this works out.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 06-05-2016, 07:31 PM   #9
Kennuck
Kennuck's Avatar
Has the engine been stroked?
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 06-06-2016, 07:09 PM   #10
davepl
davepl's Avatar
I think it's factory stroke.
Here's a picture of the piston. You can see the pin boss relief area does NOT interfere with the ring groove at all, so how or why the ring pops out when it rotates around to this area is the question.
Checked radial depth of the ring, groove depth, amount of barrel to the piston, bore roundness, piston to bore clearance, it all checks out.
As a last ditch attempt he's going to order an oil ring with increased radial depth so it'd have an even harder time getting out of the groove, but we're all still worried since no one can explain how or why it could pop out with the old one!
Old 06-06-2016, 08:17 PM   #11
1972RedNeck
1972RedNeck's Avatar
390 Ford, right?
What brand of pistons?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-06-2016, 09:02 PM   #12
haysonj
haysonj's Avatar
Rings don't rotate on the piston otherwise every manual out there would not tell you to put the gaps in a certain place on the piston. Those pistons do not require a support ring as the relief for the wrist pin does not go all the way up to the oil ring. I had one come out on me but as I look back I think I rolled it out when I put the piston in and it did destroy the bore
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-06-2016, 10:18 PM   #13
haysonj
haysonj's Avatar
After searching Google it looks like the majority of people believe the rings do rotate so I guess I have been wasting a lot of time to make sure I put the gaps where the ring makers tell me to. Once they seat I find it hard to believe they move
Old 06-06-2016, 11:13 PM   #14
saxart
saxart's Avatar
This might sound "dumb" but would it be possible for him to reassemble the engine with that piston in a different cylinder and run it? If the ring still blows out of that cylinder, then you know it's an issue with the cylinder. If the ring blowing moves with the piston, then you know it's the piston (or rings) at fault.
Just trying to help. Keep us posted...
saxart is offline   Reply With Quote
Old 06-07-2016, 05:37 AM   #15
jdw
How'd it pop out twice with no damage? Bad piston?
jdw is offline   Reply With Quote
Old 06-07-2016, 06:14 AM   #16
hamjet
hamjet's Avatar
It does sound impossible unless theres enough piston to bore clearence for a ring rail to slip by and even then I would think a problem with the compression rings to allow a high amount of blow by to force the rail out of the groove.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 06-07-2016, 12:59 PM   #17
davepl
davepl's Avatar
Here's a picture. It pops out just after it rotates around to the relief area for the pin boss. Even that would seem impossible, and it leaves a little scratch where it exits (can't see it in the photo well enough), but it does it.
He's going to try a ring that is deeper radially that should have a harder time coming out, but its still uncomfortable not knowing, even if that "fixes" it.
Everything from back spacing on the ring to the amount of barrel in the piston checks out according to spec. Checked everything we have numbers for on the piston and then some!
Old 06-07-2016, 01:57 PM   #18
jdw
He ran the piston both ways and everything specs out, I'm going with a warp/cracking/metallurgical defect in the piston that's not showing up until it heats up and or force is applied. Doesn't make sense to keep trying if the math adds up.
I'm really curious to know.
Old 06-07-2016, 03:26 PM   #19
GRX
GRX's Avatar
Strange. Have you checked that expander ring for inconsistencies and ensured it is installed correctly? Next step would be to try mixing up parts as suggested above.
^^ Not so much when everything is new. Rings will move more once the cylinders take on a bell shape, and piston skirts wear allowing them to rock in the bore. On a few occasions I have seen a high mileage engine smoke like a freight train from one or more cylinders, then clear itself out. No doubt because the end gaps lined up for a time.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-07-2016, 07:05 PM   #20
swamp rat
swamp rat's Avatar
I was also gonna suggest too large of ring gap but Hamjet already did.. I agree with Jdw its got to be the piston.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-08-2016, 04:39 PM   #21
hamjet
hamjet's Avatar
OK here it goes, I've been biting my tounge not to say what I'm about to get into. piston to bore clearance is lets say .003, Your oil ring rail is ,(just a guess) .015 .020 thousands. It is IMPOSSIBLE for an engine with correct clearance for this to happen, let alone make a 90 degree turn for it to happen with out tearing something up. The engine bore or piston is not in specs with each other, plain and simple. I hope you don't take offence to this Dave, but your friend didn't check something correctly. Every one can over look something, (except me, I'm perfect) LOL. don't get mad at me, but common sense tells me its impossible....OK, I'm pushing the button. Joe
Thanks, Joe..
Old 06-08-2016, 05:48 PM   #22
Kennuck
Kennuck's Avatar
You are exactly right hamjet, that's why I asked if it was stroked. It seems to me the only way this could happen is if the oil ring is coming out of the bottom of the bore on the downstroke.
1970 Short Wide
Vintage Air
Old 06-08-2016, 10:05 PM   #23
davepl
davepl's Avatar
That'd certainly account for it, I'll check into it. I do not know whether the engine has been stroked (I don't think so, but anything's possible, it's not mine). I'll check!
Old 06-09-2016, 12:29 AM   #24
swamp rat
swamp rat's Avatar
I'm with you and Hamjet, i would like to see this ring after it comes out the bottom.
Also if it does come out the bottom then the cylinder should show some kind of damage, the thickness of that bottom ring is thicker than the boar to piston clearance, it should be catastrophic. Bore to spec, proper piston, it should show damage of that is infact happening.
A block clearanced for a 383 stroker would have the machining perpendicular to the wrist pin, even if it came out there it would still show some damage.
I keep thinking look inside the piston bottom and ring groove for a casting flaw? but you would think the piston would have a catastrophic failure..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
