Old 06-04-2016, 02:12 AM   #1
In The Ten Ring
Heater box questions: reassembly.
I am finally getting close to the point where I can reassemble my heater box. I bought a gasket set from GMC Pauls. Do those gaskets need to be glued in?
I seem to remember the parts that enclose the back of the heater box held in not only with rivets but with a type of "caulk." What should I use to replace that?
Also, I bought the round rubber gasket that attaches to the heater box around the fan and squishes up against the front of the cab. What is a good adhesive to stick that to the back of the heater box?
(You can see the round rubber gasket I am talking about here).
In The Ten Ring is offline   Reply With Quote
Old 06-04-2016, 08:44 AM   #2
midniteblues
midniteblues's Avatar
Re: Heater box questions: reassembly.
I used weatherstrip adhesive and a big worm gear hose clamp to glue and hold the fan seal ring on.
Brush on Contact adhesive should work also.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-04-2016, 11:54 AM   #3
F.A.A.benny
For the "caulk" I use gum cord
F.A.A.benny is offline   Reply With Quote
Old 06-04-2016, 05:46 PM   #4
midniteblues
Thanks couldn't remember the name of the caulk.
I think some call it strip caulk.
I used some of the strip caulk rolled up thin (kinda like rolling pretzel dough) then flattened it out too seal up the metal panels before I screwed and rivits them on.
oh and also used aluminum(no rust)pop rivits where I drilled out the originals.
Don't forget too lube the flaps. And test that heater core.
A thin layer of the caulk around the fan flange also.
If you have big gaps in the heater box around the heater hose nipples now would be the time too address them.
I didn't like the seals I got in the "kit" for that area so I used two differnt sized valve cover grommits.
Old 06-04-2016, 06:33 PM   #5
swamp rat
swamp rat's Avatar
It was just suggested to me by Frank of Franks Pick um up Parts Board vendor to buy a roll of self sticking closed cell weather stripping to do the box, I haven't looked for that yet so my interest in this thread. He also sells the round doughnut for the fan box that is exact to the original unlike most cheap Chinese imitations, he showed me both and they are way different.
Now i need to know what Gum cord is..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-05-2016, 06:04 PM   #6
In The Ten Ring
Excellent suggestion! I just emailed that guy, thanks for that.
Old 06-06-2016, 02:52 AM   #7
F.A.A.benny
You can pick up gum cords at most hvac supply houses. But you will have to buy way more than you need
Old 07-25-2016, 11:37 PM   #8
In The Ten Ring
Do I still need "gum cord" if I bought the gasket that fits into the groove around the heater box?
Old 07-26-2016, 01:04 AM   #9
swamp rat
swamp rat's Avatar
does it seal tight?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-26-2016, 01:09 AM   #10
In The Ten Ring
No idea, I haven't tried those yet but I hope to tomorrow.
Old 07-26-2016, 02:08 AM   #11
F.A.A.benny
I'm guessing if you have a gasket then no need for the gum cord. There wasn't a gasket used from the factory other than the round one
Old 07-26-2016, 01:58 PM   #12
In The Ten Ring
Bad news! It seems I was sent the wrong gasket set. I just emailed GMC Paul's so hopefully he can help me out.
Old 07-26-2016, 02:05 PM   #13
davepl
davepl's Avatar
FWIW here's the 3M Strip Caulk in 1 foot lengths. I'm sure other sizes are available:
https://smile.amazon.com/3M-08578-Bl...3m+strip+caulk
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-26-2016, 04:08 PM   #14
In The Ten Ring
OK, GMC Paul's got back with me and gave me some instructions on assembly. Apparently I do have the proper gasket set. If I cannot figure it out, I'll go for the gum cord.
Old 07-26-2016, 04:13 PM   #15
In The Ten Ring
Is that what you used?
