Old 06-06-2016, 12:13 PM   #1
SIKKI-6
Drip rails
I am working on a 71 C10 truck. Is it seam sealer that is used along the top and sides of the drip rails? What is the best stuff to use to redo those sections?
Thank you for any advise!!
Jon
SIKKI-6 is offline   Reply With Quote
Old 06-06-2016, 12:57 PM   #2
Trevor
Trevor's Avatar
Re: Drip rails
Yes it's seam sealer.
Evercoat 6023 "Control Flow"(2-part epoxy, 2-plunger gun req'd) is best and what I use for exposed seams like drip rails, but 6022 or the single-plunger alternatives 822 or 823 I've heard work just about as good.
Trevor is offline   Reply With Quote
Old 06-06-2016, 02:05 PM   #3
SIKKI-6
Re: Drip rails
Thank you very much Trevor! I will definitely try it out.
Old 06-06-2016, 11:33 PM   #4
rsgt
rsgt's Avatar
Re: Drip rails
I recently sealed my drip rails. I did not have the duel cartridge gun. you can see how I did it here: http://67-72chevytrucks.com/vboard/s...=698292&page=2
rsgt is offline   Reply With Quote
Old 06-07-2016, 06:10 PM   #5
SIKKI-6
Re: Drip rails
RSGT, how did you remove the old seam sealer? The seam sealer that is on there now is just a little cracked on certain parts so I figured I would just replace it all.
Old 06-07-2016, 09:30 PM   #6
rsgt
rsgt's Avatar
Re: Drip rails
I used a hammer and a screwdriver and a wire brush on a drill.
