Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-10-2016, 08:12 PM   #1
Blue Rat
Panhard bar with aftermarket rearend.
I have a Strange 9in rear end with a back brace in a 1971 Chevrolet SWB C10.. I'm curious of those that have a similar rear end set up. What Pan Hard bar or track bar are you using?
What fits in other words?
Blue Rat is offline   Reply With Quote
Old 06-10-2016, 09:50 PM   #2
vidman
vidman's Avatar
Re: Panhard bar with aftermarket rearend.
I just used a Nascar trac bar and welded up some mounts..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-10-2016, 10:41 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Wish I could say I'm using this.. but I ordered the kit, built the wishbone, and it fits the 4link bracketry perrfect. But I just don't see how it is more stable than a diagonal link. So it sits on the shelf until my hard head can rationalize it.
They are used on 4000HP Promods and outlaw cars,, so they work. But my thick skull just can't 'see' it so .......
http://www.small-block-chevy.com/ima.../WHISHBONE.jpg
Oh wow thats a huge picture,, linky linky
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-11-2016, 09:56 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That is a very nice setup!
I see what you see... With the heim-joints, it looks like it would allow too much side to side movement. But somehow it doesn't?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-11-2016, 01:04 PM   #5
Super73
Super73's Avatar
The triangulation on the wish bone (3 points) does not allow for shift. You have to also consider the effects the 4-link bars have on it. This is a sytem. Yes the balls in the heirs are free to rotate and spin but, you would have to bend the bars in order to get rear end shift. If the 4-link (or even 3-link) left/right bars were not there the rear would rotate based on the single link end. But it can't because those bars are keeping the wheelbase the same.
If the rear were to move to the passenger side keeping wheel base the same, the right wishbone link would have to get longer while the left would get shorter.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-11-2016, 03:19 PM   #6
GASoline71
GASoline71's Avatar
That makes total sense! Thanks for explaining that!
Marv... weld that sucker in!
Gary
Old 06-11-2016, 03:22 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
CPP makes a 'bent' trac bar that's made for clearance on rears with diff girdles, back braces, etc. I'm using one on my '69 with a braced Moser diff cover, but the mount that comes with the CPP mounts low on the pass side trailing arm, so it's hard to get it near parallel with the axle. I ended up using the CPP bent bar with and ECE mount that looks nearly identical to what vidman has on top of his pass side trailing arm.
https://www.summitracing.com/int/par...2021/overview/
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-11-2016, 05:13 PM   #8
GASoline71
GASoline71's Avatar
I don't have a race truck by any means... Just a 1972 GMC C15, with a snotty 355 and a worked over TH350. The stock 12 bolt rear end housing with an Eaton Posi, Moser axles, and Richmond 3.73's hung on the stock coil sprung rear end.. I have a thick Moser diff cover with the cap girdles and it clears the stock panhard rod just fine. I thought it was kinda odd when I bolted it on as I had always read where cats had a prob with the bar hitting the thicker covers.
Gary
Old 06-11-2016, 08:34 PM   #9
Blue Rat
I haven't checked mine yet. But, I don't think it is going to fit. Going to check it first. I'm doing some looking ahead of time.
Old 06-12-2016, 07:04 AM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Gary
I think it's the long aftermarket panhard bars that mount across the rearend on the pass side trailing arm most people have trouble with in regard to the aftermarket diff covers.
Adam
Old 06-12-2016, 03:35 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
found a pic - hope this helps you Blue Rat - it might give you an idea of how far out the CPP bar kicks out.
Adam
Old 06-12-2016, 09:32 PM   #12
Blue Rat
That is definitely a good ways out. I want have to worry with that bar.
Thanks Boss.
Old 06-14-2016, 09:10 PM   #13
vin63
It's Better With Nitro
vin63's Avatar
A long time ago, I had more obstacles behind my rearend housing, so I fabricated a track bar with a couple of bends in it to clear them (fuel pump and filter) mounted to the opposite trailing arm, similar to some of the off-road race truck bars I did back then. Fast forward 15 years, and I've since relocated the fuel pump/filter combo, but kept the track bar. Mine is similar to what CPP offers today...I would just buy that if I had to do it over now.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-15-2016, 02:27 PM   #14
Rannos
Rannos's Avatar
My Moser 12 bolt cam with a bent Panhard bar and high mount bracket. I can get pictures of it when I get home if you like.
Rannos is offline   Reply With Quote
Old 06-15-2016, 07:40 PM   #15
Blue Rat
If you don't mind. Here is a pic of the rearend. Its in the truck now.
Old 06-16-2016, 12:22 PM   #16
Rannos
Rannos's Avatar
Here is my Panhard bar. Came with the bracket that goes around the trailing arm and a new mount I welded to the frame.
Old 06-16-2016, 03:53 PM   #17
68racer
Yeah baby!
68racer's Avatar
In a discussion on panhard rods on another forum I learnt about the Mumford Link, probably too much for street use but could be easier to package on a trailing arm truck than a watts linkage.
http://www.not2fast.com/chassis/mumford.shtml
11.37 @116
68racer is offline   Reply With Quote
Old 06-21-2016, 03:33 PM   #18
contagious102
contagious102's Avatar
Had to do the same with mine, bent it my self to fit .
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 06-26-2016, 11:01 PM   #19
BossHogg69
motor exploder
BossHogg69's Avatar
That's a pure work of art there! What brakes are those?
Adam
Old 06-28-2016, 07:29 AM   #20
Blue Rat
Wilwood
Old 04-27-2019, 05:05 PM   #21
Moutzygun
Gary
Moutzygun is offline   Reply With Quote
