Old 06-15-2016, 09:58 AM   #1
CYLFD
CYLFD's Avatar
Arrow 2 Tires, Coker BF Goodrich, 285 /70R15, Radial, Wide Whitewall
2 New Tires, Coker BF Goodrich, 285 /70R15, Radial, 3.50 in. Wide Whitewall with powder coated chevy rally wheels.
No shipping at this time, i have them listed locally on CL as well.
New tires these cost $287.00 each and $40.00 a wheel for powder coating you get them for $450.00
Brand:Coker Tire
Product Line:Coker BFGoodrich Silvertown Radial Tires
Tire Size: 285/70-15
Wheel Diameter: 15 in.
Sidewall Style: Whitewall
Tire Construction: Radial
Tire Diameter: 30.75 in.
Tire Diameter Range: 30-30.99 in.
Section Width: 11.50 in.
Tread Width: 8.60 in.
Minimum Recommended Wheel Width: 7.50 in.
Maximum Recommended Wheel Width: 9.50 in.
Directional: No
Asymmetrical Tread Pattern: No
UTQG Tread Wear Rating: 320
Tread Depth: 12/32 in.
DOT-Approved: Yes
Tube Required: No
Max Load Single (lbs): 2,679
Notes: 3.500 in. whitewall width.
These BFGoodrich Silvertown radials from Coker Tire are great for classics, hot rods, and customs. Available in classic whitewall and redline styles, these tires are S speed rated and are DOT and ECE-approved. Silvertown radials feature a high-tech, all-season tread design and are great for big and little combos. Tires with 13 to 16 in. rim diameters are available. They're the perfect tires for your cruising car!
CYLFD is offline   Reply With Quote
