Old 06-16-2016, 08:44 AM   #1
Hodakakid
fan shroud woes
Hey all
Brand new member here - I bought a 1972 Jimmy and needing some advice. A previous owner installed a later model 350 v8 out of a late 90's Suburban (from what I'm told) changed the fuel injection to carb. There is also a dual electric fan setup. Somewhere along the line the shroud was removed from the electric fan and not ever replaced. I'm wanting to put a shroud back on so, my question is: What's the best way to tell if the electric fan setup is an aftermarket brand ( no markings or labels/tags anywhere) or perhaps a radiator swap from the Suburban (along with the electric fan setup)? Did Chevy use electric fans on late 90's suburbans? The fan blades are metal. What are some ideas about going about finding a replacement?
thanks in advance for any ideas. i'm not opposed to starting from scratch and buying another electric fan setup, but then again would rather not spend the money if there is a simpler, easier solution. If buying a new fan setup - I;m still needing to know if it's a Stock or Suburban radiator...
Hodakakid is offline   Reply With Quote
Old 06-17-2016, 10:25 PM   #2
elkniks
elkniks's Avatar
Re: fan shroud woes
you need to post photos so we can all see what ya got there
elkniks is offline   Reply With Quote
Old 06-20-2016, 07:57 PM   #3
87Skier
87Skier's Avatar
Re: fan shroud woes
I've got a 1996 Suburban and have worked on stuff up to 2000. I have never seen one that had a SBC and had anything but a mechanical fan with a clutch.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 06-21-2016, 11:50 AM   #4
buckkoo
buckkoo's Avatar
Re: fan shroud woes
Agree with 87Skier.
And you need to match the shroud to the fan, so if you want a 72 shroud, you would need to go back to a mechanical fan, otherwise the electric fans won't be able to capture as much air to move and cool the engine.
buckkoo is offline   Reply With Quote
Old 06-21-2016, 12:21 PM   #5
chastain90
chastain90's Avatar
Re: fan shroud woes
Not sure if this helps but I have a mechanical fan(for now) and I used a shroud off a late 70s early 80s chevy van and it fit perfect. Even had the same deluxe side marker lights as well.
chastain90 is offline   Reply With Quote
electric, fan, jimmy, radiator, shroud
