06-22-2016, 09:12 PM | #1 |
Senior Moment
How are you mounting the slave Cly for hyd clutch
I'm running a LS1 and T56 six speed. Where are you guys mounting the slave cylinder for the clutch. Pics would be greatly appreciated
Thanks Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
06-23-2016, 10:45 AM | #2 |
Re: How are you mounting the slave Cly for hyd clutch
Here is how I mounted the one on my son's truck. This is a 5.3/T-56 set up.
06-23-2016, 05:53 PM | #3 |
The master looks great, any pic of the slave on the bell housing, or are you using a Hyd. throw out bearing?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-23-2016, 06:04 PM | #4 |
Hyd throw out bearing.
Edit: my bad, I just noticed you are asking for slave cyl mounting pics. |
06-24-2016, 09:13 AM | #5 |
I believe everyone uses the stock arrangement of hydro throwout bearing for the T56 clutch slave.
06-24-2016, 12:04 PM | #6 |
I'm not sure how you would do a fork with outside slave setup on a t-56 as there are no provisions for a fork pivot etc. I'm sure it could be done but not sure why you would.
06-24-2016, 07:04 PM | #7 | |
Senior Moment
Thanks Steve
