Old 06-27-2016, 05:40 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
MOTOR MOUNTS - I6 to V8
Getting ready to change out the I6 to a 283 in my sons truck.
I've read that the motor mounts that are currently in the truck will work fine. Correct?
My question is what mount do I need that attach the truck mounts to the mounts that actually attach to the motor?
Also, are there any other issues that I will need to think about with this swap? I'm assuming that the drive shaft length may be an issue. Anything else?
'63MurderTruck is offline   Reply With Quote
Old 06-27-2016, 06:44 PM   #2
62stepside longbox
62stepside longbox's Avatar
Re: MOTOR MOUNTS - I6 to V8
It depends what straight six it has, if it's a 230 then yes but if it's a 292 then you will need to change the passenger side mount
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-27-2016, 07:51 PM   #3
padresag
if it is a 230/250 you have everthing there already. the insulator(rubber mount )bolts directly to the block
the 292 has a different perch. the piece that bolts to the frams and xmember
the throttle bellcrank that come thru the firewall has a different nengine side lever too
ron
padresag is offline   Reply With Quote
Old 06-27-2016, 08:09 PM   #4
'63MurderTruck
ron
It has a 250, although it's NOT the original motor. I have no ideas what the original motor was. The side mounts that's affixed to the motor now 'look' way too tall. They 'look' liked thay'd hit the headers on the 283
Any idea if the driveshaft will need to be shortened/lengthened?
Old 06-27-2016, 08:12 PM   #5
padresag
the bellhousing mounts in the same place so that means so does the trans.
ron
Old 06-27-2016, 11:52 PM   #6
Captainfab
60-66 Nut
The I6's have a bracket between the engine mount and the block. Remove those and bolt the engine mounts directly to the small block. It is all very simple.
Old 06-28-2016, 12:03 PM   #7
65 C20
If you are asking which rubberized mount to use, I used
Auto Extra 2282.
Cal.
65 C20 is offline   Reply With Quote
