Old 06-28-2016, 06:24 PM   #1
Thesilverfox
Thesilverfox's Avatar
Mike D's 50 pickup build
So I figured I'm pretty deep into my build and want to post photos for you guys.
I have a very long way to go but its been fun so far.
Will post comments later on the new components.
Thesilverfox is offline   Reply With Quote
Old 06-28-2016, 08:54 PM   #2
Thesilverfox
Re: Mike D's 50 pickup build
To explain pics above, I got TCI's Custom front IFS with GM big brakes and Ridetech bags. If you look at the pic of the with the front IFS you'll notice that its fully slammed and there is almost no camber which s pretty sweet. Hard to see in pics but this is really nice stuff. Was kinda drooling when i was opening the boxes.
The rear is TCI 4 link with Ridetech bags. It's going to be mounted to a ford 9 inch. Front and rear suspension will have sway bars.
I am in the process of c notching the rear and installing the fronts. Will completely box the frame with the Tig welder. I have made the decision to Install Billet precision lengend Mag wheels in 20x10 rears with 4 " B/s and 18x7 fronts with 3 1/2" B/S. So will have to shorten the rear axle and frame.
Will set the rear to front rake at 2 degrees. Did mock-up measurments fully slammed, with the wheels selected, floorboards will be approx 2 inches from the ground.
Installing 6L LS LQ4 engine from a 1 ton wrecked chevy express van. Checked out the Con Rod caps and bearing are in great shape. Putting a Comp Cam xtreme tri power plus and will use factory intake manifold and reclamed wiring harness from truck. As a reference, we just put a 62 Apache truck with the same engine camshaft configuration and got almost 400hp at the wheels so that is good enough for me. I have a Dyno at work which is a pretty sweet toy.
The tranny is a 4l80e.
This is the look i'm going for.
http://stancewords.stanceworks.netdn...bagged-old.jpg
Here's a better pic of the front end.
Old 06-28-2016, 09:19 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Old truck with lots of new parts..hard to go wrong with that..be a good looking ride when done..patina finish?
Old 06-28-2016, 10:42 PM   #4
dug224
dug224's Avatar
The fun begins! Will be following along. dug
dug224 is offline   Reply With Quote
Old 06-28-2016, 11:23 PM   #5
oldman3
oldman3's Avatar
I'll tag along, looks good so far and sound like a great build...Jim
oldman3 is offline   Reply With Quote
Old 06-29-2016, 08:58 AM   #6
SalvagedSouls
SalvagedSouls's Avatar
I'll follow along as well.
-Jonathan-
1949 - 3600 Update suspension, engine and drive it.
http://67-72chevytrucks.com/vboard/s...d.php?t=691034
1953 - 3100
1955.1 - 3100 Bare Metal Build
http://67-72chevytrucks.com/vboard/s...d.php?t=691261
1965 - Buick Special & 1965 Buick Skylark
SalvagedSouls is offline   Reply With Quote
Old 06-29-2016, 10:23 AM   #7
MIKESAD50
I'll be following along, will be a cool truck.
Mike
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 06-30-2016, 09:16 PM   #8
Thesilverfox
Been working on the engine cosmetics for a while now and I think it's an improvement so far. Will let everything dry for a few days then get back to it.
Old 07-01-2016, 12:06 AM   #9
84blaze
Looking good!
84blaze is offline   Reply With Quote
Old 07-01-2016, 09:42 AM   #10
Thesilverfox
Yes, i'm going for the slammed style patina finish. I'll try to keep the exterior and cab interior as original as possible.
Old 07-01-2016, 02:11 PM   #11
joedoh
joedoh's Avatar
nice clean start!
are you going to use that 47 gmc grille? thats a 1.5 year only piece, and my favorite. I did a 47 gmc last year.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-01-2016, 02:58 PM   #12
Thesilverfox
Originally Posted by joedoh View Post
nice clean start!
Thanks, that grille was laying in the box of this truck and the previous owner did not care to keep it. He just gave it to me. Will keep it for a future project. Its got a great patina.
Old 07-01-2016, 03:34 PM   #13
Thesilverfox
Also got some fog lights at an estate sale for $5.
Got a 1956 Oldsmobile hood ornament that I might use.
And some vintage licence plate holders from my home town.
Old 07-01-2016, 06:58 PM   #14
mongocanfly
Post Whore
Good score on license plate holder...and the grill..you could take the gmc grill and a couple of them yellar lights and make some cool wall art till you get ready to use it..
Old 07-06-2016, 09:21 PM   #15
Thesilverfox
Engine pretty much done detailing. Cam should be here in a few days. Got a new timing chain and behive valve springs also. Don't know what size pushrods I need so will install cam first and figure it out. Buddy's got a fancy adjustable pushrod for me to use.
So finally started the cab, scary stuff in there. It's tough to fix a cab while maintaining that rusty exterior. Anyway this pic is when i was getting started this morning. Made pretty good progress but forgot to take pic.
Frame is now getting put back together and rear axle width is figured out. Am putting 10" wide tires with 315r35 20" tires. Frame is presently beeing narrowed. Will tub it from the inside. Will post pics soon. All rivets have been removed and nuts welded-in instead. Lots going on this week. Am on holidays.
Got a lot of ol'school hot rodders taking a look at my project and they dont get that Patina lowrider stance i'm going for, lol.
Old 07-07-2016, 10:44 PM   #16
Thesilverfox
Cab getting worked on, was in the process of cutting pitted areas when i took picture. Also removed visible pits on top. Sandblasted and rust treated that specific area.
Here's the frame getting boxed and narrowed.
Old 07-09-2016, 11:38 PM   #17
Thesilverfox
But welded, rust treated and primed inside kick plates today, Makin some progress.
Old 07-12-2016, 11:29 PM   #18
Thesilverfox
finished getting floors in today, woohoo.
Old 07-13-2016, 08:12 PM   #19
Thesilverfox
Got some goodies today.
Went to a local car show this weekend, saw some cool rides.
Old 07-13-2016, 11:31 PM   #20
84blaze
Right on man everything is looking great! I was in Lethbridge last weekend for the street wheelers weekend. I hope to trailer my 49' to down there to Battle at the Bridge for next years show.
Looking forward to updates.
Old 07-17-2016, 09:46 PM   #21
Thesilverfox
Sweet, see you then and keep in touch. Don't know if mine will run next year but we'll see.
Buddy was ol'school fusion welding the cab corners for me today. Ohhh yeah.
Old 08-31-2016, 07:54 PM   #22
Thesilverfox
Frame update. Almost complete.
Old 08-31-2016, 11:50 PM   #23
Flysocal
Man that frame is looking really good. Keep up the great work!
Flysocal is offline   Reply With Quote
Old 09-01-2016, 08:36 AM   #24
Thesilverfox
Thanks, it'll be ready for some serious LS power. Next step is to get me some Dutchman 31 spline axles and some rear willwood brakes. Also have the tank and fuel system to mount. Cant wait to get the wheels but am running out of cash so will have to wait a few months. I was checking out Billet specialties and really like the mag series but have found some 20 inch smoothies on their facebook page so will look into that. The axle has been shortened to 50 inches so it will take some 20x10's in the rear. Also the slammed ride height will set the boards 2 inches of the ground without having to raise the box or notch the frame. I also have a rear sway bar in the rear if you can see so it should handle well.
Old 09-09-2016, 11:22 PM   #25
Thesilverfox
This weekends goal is to get the cab fitted with the engine and trans. These wheels are just there to move the truck around. Also Got all my rear axle parts coming, should have them late next week. The first thing to hit the ground is the oil pan so gotta get myself a low profile one ASAP.
