Old 06-30-2016, 11:03 PM   #1
mikebGMC70
Need guidance on rear suspension options
Hi, I have a 1970 gmc 2500 with leaf spring rearend.
I'm wanting to run bags front and back. I am doing drop spindles in front and notching the rear. I need advice on options for the rearend. I am not trying to go fast, just cruise around and use it for lite truck work. I did some research but I'm starting to get lost in the weeds.
I am looking at air over leaf with 3 leafs left in. It's the cheapest but has its drawbacks plus I'm assuming limited travel.
I was looking at triangular 4 link using a universal weld on set as its on the cheap side but have no experience with the setup.
Any advice is greatly appreciated
mikebGMC70 is offline   Reply With Quote
Old 07-01-2016, 07:52 AM   #2
chase@ridetech
chase@ridetech's Avatar
Re: Need guidance on rear suspension options
On a leafsprung C-10 like yours I would go with a parallel 4 -link. They are relatively easy to set up.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 07-01-2016, 07:53 AM   #3
chase@ridetech
Here is a universal parallel 4-link install video. Its on a Ford, but the general install is very similar.
Chase Mundy
Old 07-01-2016, 09:16 AM   #4
drfloyd
I'm almost done with my 4 link install. Relatively easy depending on what you buy I would imagine. And if you go bolt-on vs. weld-on. I installed the bolt-on but will be welding it in prior to powder coat. The only real issue that I have struggled with is determining the exact ride height while working on a bare frame.
drfloyd is offline   Reply With Quote
Old 07-03-2016, 04:42 AM   #5
andrewmp6
You could do http://www.nolimitengineering.com/pr...tegory=6157532 or a 3 link http://www.nolimitengineering.com/pr...tegory=6157532
andrewmp6 is offline   Reply With Quote
Old 08-20-2016, 07:56 PM   #6
mikebGMC70
Thanks for everyone's reply. Would a factory trailing arm be better for daily driving with airbags? Is a 4 link like the fatbar setup overkill for a daily driver?
