Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-19-2016, 03:23 PM   #1
docrock
docrock's Avatar
1941-46 Radiator
I am looking for a new aluminum radiator for my project. I have a very bad original and it looks like the filler is on the passenger side and on top. All the aftermarket units all have the filler pushed toward the engine. Doesn't that hit the radiator support rods?
Has anyone found a radiator that fits correctly?
I am running a sbc and 700r4
Thanks for any help
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 07-19-2016, 05:56 PM   #2
paintman
Re: 1941-46 Radiator
All I can tell you from my experience is the Champion Radiators that they claim fits the 46's.......DO NOT! The cap hits the cross braceing comming off the firewall. Its an easy enough fix. The other thing you might have to do is have the filler neck turned 180 degrees as the coolant overflow nipple points towards the drivers side of the truck. You can have Champion change the oreintation of the nipple but I think it cost me about 75 bucks, and they did crapy job of it. Not sure if you have checked out my build but I chronicle all this over on the pre 46 projects side of this site.
paintman is offline   Reply With Quote
Old 07-19-2016, 07:07 PM   #3
docrock
docrock's Avatar
Thanks Paintman. I was looking at your project and your fix looks very clean to me.
I will order a radiator and now know what I am in for.
Old 07-19-2016, 09:56 PM   #4
paintman
Hey Doc! Just as a side note. If you do go with the Champion radiator, the good news is, it will bolt directly into the stock radiator core support. It's just all the other B.S. you will have to deal with
Old 07-20-2016, 12:42 AM   #5
solidaxel
solidaxel's Avatar
Take a look at PRC radiators, I will say that they keep the engine on the thermostat here in the desert and it has been a "bit warm".
It stays within 10* with the A/C on in traffic
I wish the Vintage Air worked as good as the rad and fan!
I am sure others will work but we only tried this one and it works...................get out your wallet!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-20-2016, 01:07 AM   #6
docrock
docrock's Avatar
That looks great. I found a company called superior radiator. USA made in aluminum with correct fitting and filler locations for 270. plus shipping.
Found them on ebay. raddas is there tag name.
I will post how it works out when I get it.
Thanks for the responces
Old 07-20-2016, 01:20 AM   #7
solidaxel
solidaxel's Avatar
I am looking for one for a 33 Plymouth, is this correct name?
0 results found for raddas, so we searched for radias
LS 3 4L70E
Old 07-20-2016, 12:35 PM   #8
docrock
docrock's Avatar
My mistake. dissrad
Old 07-20-2016, 01:07 PM   #9
solidaxel
solidaxel's Avatar
LS 3 4L70E
Old 07-23-2016, 05:09 PM   #10
SparkyRnD
SparkyRnD's Avatar
We also make radiators here in the USA using domestically sourced materials by hand. They are all tig welded, no epoxy or glue either. Plus, we are a site sponsor. We don't currently make them for the 41-46 models, but we do for the 47-87 models. We'd be interested in building a prototype and would cut a deal in exchange for sending us your rad, and then test fitting the prototype. Let me know if you are interested.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 08-07-2016, 01:36 AM   #11
docrock
docrock's Avatar
Thank you for the info. I had already ordered one. Good to know that you can make them tooName:  20160803_124613.jpg
Old 08-07-2016, 01:49 AM   #12
solidaxel
solidaxel's Avatar
Re: 1933 Plymouth Radiator
We have a "good" stock radiator that is part of the core support for the 33 2 door Plymouth sedan we are building but will need a rad for a 383 Mopar
What does something like this run?
LS 3 4L70E
Old 08-07-2016, 05:59 PM   #13
SparkyRnD
SparkyRnD's Avatar
email pictures and details about the set-up (dimensions as well) to sales@rndfabrication.com and I can quote you. Typically, custom one-off radiators are in the $475-550 range, but it really depends on complexity / size / etc.
Old 08-11-2016, 06:07 PM   #14
solidaxel
solidaxel's Avatar
Check your Junk mail !!!
LS 3 4L70E
