Old 07-21-2016, 01:30 PM   #1
engineer_gregh
engineer_gregh's Avatar
Three nub versus four nub with disk brakes
Four of the five wheels are three nub 5 lug wheels. Will they work on my 71 with factory disks and P01 hubcaps? Any help appreciated. Thanks
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 07-21-2016, 03:03 PM   #2
drewbert41
drewbert41's Avatar
Re: Three nub versus four nub with disk brakes
They will work on the rear but not on the front. The 4 nubs have the correct backspacing for disk brakes the 3 nub do not.
You can tell how different the backspacing is by looking at the sides of them. Cant tell as well with the tires on but they are very different.
drewbert41 is offline   Reply With Quote
Old 07-21-2016, 07:42 PM   #3
fb111ewo
fb111ewo's Avatar
I agree with the reply above also - you need the four nub wheels. I see you are in Smyrna and I am down in Murfreesboro - really close. I have five of the 5 lug 4 nub steel rims, but have decided to stay with the 6 lug rims. PM me if you are looking for some.
fb111ewo is offline   Reply With Quote
Old 07-21-2016, 07:56 PM   #4
engineer_gregh
Any idea what the three nub 5 lug wheels are for?
Greg Smyrna TN
Old 07-22-2016, 06:21 AM   #5
Lincolns and full-size Ford cars used the 5 on 5 pattern. I'd try and see, if they are the same as the 4-nub in all other ways. I discovered the nub thing on 6-lug wheels and can only assume it's the same for 5-lug, but could be wrong. I also have seen someone put a 3-nub 6-lug with disc brakes before. So, not a 100% way to know
Old 07-22-2016, 08:22 AM   #6
engineer_gregh
Thanks special-K. The guy says they are the original wheels off his 72. I'm going to try them and will post what happens.
Greg Smyrna TN
Old 07-22-2016, 01:20 PM   #7
drewbert41
drewbert41's Avatar
72 should clear disk no matter what I'd think.
Old 07-23-2016, 07:46 AM   #8
Let us know how that works. Always something to learn. It seemed a great way to tell the early drum 6-lugs (all GM 1/2t) from the '71-up K/10 wheels. But there was that member who showed he mounted some 3-nubs on his K/10 with discs. Other companies made wheels besides the OEM suppliers and maybe they had/have centers made to fit discs but their stamps have 3-nubs. The question doesn't really come up for 5-lugs since all those "factory" wheels were made for disc brakes.
I would see these 15 x 8 5 on 5 steelies are a swap meet, but they had 3-nubs. I passed them up a few times. I figured they were from an earlier big Ford car with drums. But also one bead was pretty rusty, or I may have gave them a try.
Old 07-30-2016, 06:25 PM   #9
engineer_gregh
Ok mystery kind of solved. Picked up the wheels today and they are in fact 4 nub. The guy I bought them from just didn't know what he was looking for when I asked him the question. So I'm going to assume that 71 and 72 5 lug trucks do require 4 nub wheels until its proven otherwise.
Greg Smyrna TN
Old 07-31-2016, 06:51 AM   #10
Till proven other wise is right. Lesson learned today is sometimes word of mouth is inaccurate
Old 07-31-2016, 07:19 AM   #11
GR8-68
GR8-68's Avatar
No way !! This is the internet, after all everything you google is true, you should know this. Even Abraham Lincoln said you couldn't believe everything you read on the internet.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
