07-22-2016, 10:09 PM | #1 |
'68 396 exhaust hanger question
Does anyone know if these exhaust hangers are correct for a '68 big block? I'm pretty sure I know the correct locations but my frame does not have all of the holes drilled that are needed for these brackets. Would a '68 big block truck use different hangers? My truck is a short bed with coil spring rear suspension.
07-22-2016, 11:18 PM | #2 |
Re: '68 396 exhaust hanger question
Is your truck leaf or coil springs? The reason I ask is because the brackets pictured look exactly like a set I removed from a 72 long bed big block with coil springs. I installed them on my 72 small block truck with coil springs. No issues whatsoever all the holes were in the frame and cross member. I believe the leaf spring trucks use different brackets. Hope this helps.
07-23-2016, 08:52 AM | #3 |
Mine is coil spring, I should have specified. My '68 frame doesn't have the holes needed for these brackets, I'm fine with drilling them as long as the brackets are correct for a '68. I'm trying to put it back to the way it would've come from the factory.
07-23-2016, 09:48 AM | #4 |
if you start a build thread i'd love to follow. i have a 68 swb 396 truck and i'm alwys interested in its originality too.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
07-23-2016, 06:01 PM | #5 |
I thought about starting one but my progress has been so slow there wouldn't be many updates. Does yours have these brackets? I'd love to see some pics. I'll check out your build thread.
07-25-2016, 10:00 PM | #6 |
Bump, anyone with a factory '68 396 truck?
07-28-2016, 07:48 PM | #7 |
Active Member
I have had 4 factory BB trucks, the hangers you have in the pics are from a 1972
I will post pics of correct brackets |
07-28-2016, 07:56 PM | #8 |
Thanks Steve, looking forward to the pics.
07-28-2016, 10:40 PM | #9 |
Active Member
This is the style brackets used on 1967-71 trucks.
1968 - 71 Big Block trucks used a double set, same brackets on both sides. From the top, the two angle support brackets rivet to the frame these are the forward support brackets, hanging from these are the rubber insulators with hanger support riveted on, around the hanger support is the pipe band or strap. Not in the pics intermediate support bracket; there is a bracket that wrapped around the body of the muffler, Im not useing Im not going with factory size mufflers. On the bottom this is for tail pipe support; rubber insulators, hanger supports and tail pipe strap. Not in the pic or the small tail pipe support brackets they are riveted to my frame, " youve seen them Im sure, just a couple inches long they have a one quarter twist in them " I can get pics of them if you need but you should have them on your truck they are all the same 67 -71 Big and small blocks Last edited by burb71; 07-28-2016 at 11:22 PM. |
07-28-2016, 11:18 PM | #10 |
mine do not appear to be original.
07-28-2016, 11:43 PM | #11 |
Active Member
Lets see what you have?
Im just going on all the trucks I have had. |
07-29-2016, 01:23 AM | #12 |
mine has had quite a few mods over the years, so it's anyone's guess...
07-30-2016, 12:37 AM | #13 |
Are the replacement rubber insulators, band clamps, etc. reproduced?
07-30-2016, 12:51 AM | #14 |
Active Member
The large and small rubber insulators I got on ebay NOS GM, sticker on the bottom of hanger support.
The two hanger supports at the bottom are repro off ebay Pipe band or straps also repro The hanger brackets I got from parts trucks |
07-30-2016, 09:55 AM | #15 |
Active Member
There are a full NOS set of the insulators to be had on ebay now, The 2 forward type are each sold by 2 diff guys, and another guy has 5 of the rear insulators. ( none are mine )
You have to get the hanger brackets from somone parting a truck, on the board or ebay |
07-30-2016, 11:13 AM | #16 |
What did you type in to find them? Got a link?
07-30-2016, 05:04 PM | #17 |
Active Member
I dont know how to link
Ill pm you my phone # call or text me Ill hook you up with the ebay item #s |
07-01-2018, 07:02 AM | #18 |
eagle9502
Do you still have those exhaust brackets? I need the hanger out of the bottom R hand one in picture the R side rear for my BB truck. Muffler shop lost mine |
07-02-2018, 09:04 PM | #19 |
Who Changed This?
The muffler shop ought to replace them, unless they were crusty, rusty and had to be replaced.
07-03-2018, 07:15 AM | #20 |
I agree but they said no. They said the rubber piece looked old so they took the bracket out and threw it away so I wouldn't lose it. I told them the truck was in bare frame, merely for mockup of exhaust in the original location.
