Old 07-26-2016, 12:33 PM   #1
jhcolli
jhcolli's Avatar
Hydroboost with Rack and Pinion
I've read through numerous threads on here and read dozens of articles, but can't seem to find specifics on a hydroboost working with a rack and pinion system. I've contacted CaptainFab but he said he only makes the adapter plate, doesn't know much about the HBs and how they work.
Here is my setup. LS3 with Holley TC pump for LS engines. No Limit Eng rack and pinion. I can get a hydroboost remanufactured pump from Rock Auto for just about any year it was offered in a GM truck or Astro van.
My questions are:
1. If someone has successfully used HB with a TC pump and rack, can you send me details and lessons learned?
2. Is there a particular year or part number for an HB that works better than others?
jhcolli is offline   Reply With Quote
Old 07-26-2016, 03:16 PM   #2
67 chevelle
67 chevelle's Avatar
Re: Hydroboost with Rack and Pinion
I would contact no limit , they should have your answers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-26-2016, 03:28 PM   #3
Orange Crate
Orange Crate's Avatar
I just converted to HB brakes, but I have the stock steer gear. There is a lot of good info on pumps, pressure and flow here:
http://www.pirate4x4.com/tech/billav...ng/index2.html
If you get the pressure and flow specs from No Limit you might be able to determine if the TC pump will cut it.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
hydroboost, rack and pinion
