07-27-2016, 06:56 PM | #1 |
clutch pedal design ?
Curious. Do all clutch pedals for this era of truck look like the one in this picture. Has a spring on the side of the pedal up to a bracket on the top of the pedal housing ? Seems I have one that isn't like this or it has been pieced together. Mine has a spring from the hole in the top of the clutch pedal to the housing and the top bracket is different shape.
Thx.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
07-27-2016, 07:58 PM | #2 | |
The Older Generation
Re: clutch pedal design ?
Here are the two different configurations in the same picture. I don't know when it changed but my '67 has the smaller one that angles toward the firewall and my '72 has the larger spring that goes to the center of the pedal arm. LockDoc
07-27-2016, 08:10 PM | #3 |
Ahh Thanks. Yes I have the smaller spring back towards the firewall but I had bought it second hand for a manual swap. That is why I was wondering.
07-27-2016, 10:18 PM | #4 |
Be *REAL* careful futzing around with that assembly. Many years ago, I was pulling mine out, and the pedal arm got tapped, and the spring pulled it up over-center and lopped off the end of my finger in the process. That spring is No-$#!+ serious.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
07-28-2016, 09:00 AM | #5 |
2WD Jimmy
I believe the one in the above pic is for 4 wheel drive if I remember correctly.
07-28-2016, 09:06 AM | #6 |
All about them K’s
Could be as The one pictured in the first post is the same as my K/20.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-28-2016, 01:22 PM | #7 | |
HOLY FORKING SHEEP! I can see after you describing it, it would be a perfect shear. I will make sure to advise my son of that possibility, as he is starting his first manual truck.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
