Old 08-04-2016, 08:45 PM   #1
Blue Tank
Blue Tank's Avatar
Front hub nut removal problem
Hi Guys
I've been trying to remove the front hub nut (35mm one) and it won't budge. This hub was replaced by the local dealer before I got the '04 1500 Burb with AWD. I've tried with a 35mm impact socket and a good 1/2 Ingersoll impact, not the "looks like the good one". I also broke a 1/2 Blackhawk ratchet with a short pipe on it. The 3/4" ratchet wouldn't budge it either. I'm 250 lbs and I think I can come up with 180 ft/lbs using a 3/4 ratchet.
Then I thought they might have put red loctite on it so I heated the nut to 500* and still nothing.
I don't see a thread where anybody else has had this problem. Any ideas?
Mark
69 Camaro 454 6spd/ 1st car and still have it
67 Chevelle 396 Convertible
57 GMC 1/2 t
56 GMC Napco Panel civilian defense
65 GMC v6 long panel
72 Burb
Blue Tank is offline   Reply With Quote
Old 10-15-2016, 02:30 AM   #2
izzy_Britton
izzy_Britton's Avatar
Re: Front hub nut removal problem
I had this exact problem... my solution was a little more involved than the obvious solution of slapping a tool on it.. lol
I took the knuckle off of the truck and the axle off at the front carrier. I then headed to a neighboring shop where they used a 3/4 air impact gun and was able to get it off with some difficulty. it came off!
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
