Old 08-10-2016, 09:07 AM   #1
projectking
projectking's Avatar
'68 c30 power brake question
http://m.ebay.com/itm/67-68-69-70-71...257Ciid%253A10
Is this all I need to swap out my manual drum master cyl or is there more linkage involved?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 08-10-2016, 04:10 PM   #2
projectking
Re: '68 c30 power brake question
I know there isn't a prop valve with it and only wondering if the bracket and rod pictured is all that is needed.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-10-2016, 04:21 PM   #3
kwmech
Do you have all the brackets and linkage that bolt to the firewall? AND that 10 series stuff isn't going to work on your 1 ton.
Old 08-10-2016, 05:31 PM   #4
projectking
The link has a bracket pictured, I currently have a manual master.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-10-2016, 06:05 PM   #5
kwmech
Brackets look correct. Don't need combo/prop valve unless swapping to disc on the front. You can retain the stock piece
Old 08-10-2016, 07:15 PM   #6
projectking
Thanks! I have disks up front from an '84, I'll have to source a kit with the larger booster then.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-10-2016, 07:20 PM   #7
kwmech
Do you have the proportioning valve from the 84?
Old 08-10-2016, 07:51 PM   #8
projectking
No, I only bought the frame and front suspension.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-10-2016, 07:58 PM   #9
projectking
I found a kit with an 11" booster, that's the c20/c30 diameter right?
67 Chevy C10 LWB
90 Mustang Gt
Old 08-10-2016, 11:11 PM   #10
kwmech
It may be on the front cross member near where the steering box was bolted
Old 08-11-2016, 05:34 AM   #11
projectking
I think you might be right, luckily I still have the front stub.
67 Chevy C10 LWB
90 Mustang Gt
