08-21-2016, 11:32 PM | #1 |
Almost destroyed my engine today...
Well I got pretty lucky today, it looks like I may just need gaskets and a pushrod.
I was checking lash today and everything seemed fine, I had heard a loose one and found it in the #4 cylinder exhaust valve. Tightened it up and reassembled and went for a test drive. Opened her right up turning on to the main road and felt really weird like it was misfiring. Turned around and went straight home, pulled the valve covers and the #6 intake pushrod had dropped all the way down, just barely showing enough to grab with some tiny needle nose pliers and pull it out. My Comp polylocks are not holding for some reason. It's the little Allen head screw inside the polylock, they keep stripping out even when I'm givin. Them the 8 #'s of torque the book says to use. Are there better polylocks? Anyway, grabbed a new pushrod out of my stash and tried to set it on the lifter and kept dropping it in....I thought it was an easy fix, but after shining a flashlight down the hole I can see the cam lobe where the lifter should be, so apperently the cam lobe kicked the lifter out of its hole, and now I have to tear the top end apart AGAIN and find my lifter, replace, reassemble with a new pushrod, and then get back to roasting some tire. I set a new personal record though lol 1 month of driving the truck and no wrenching Thank goodness it's not worse because I'm sure it could've been expensive |
08-21-2016, 11:38 PM | #2 | |
Re: Almost destroyed my engine today...
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-22-2016, 12:19 AM | #3 |
Go Pack Go!
I know the feeling of after spending hard earned money on something important and it turns out bad. Glad you saved a total catastrophy.
08-22-2016, 09:51 AM | #4 |
I was trying to think of some kind of magnet on a flexible stick to fish around in there and grab the lifter, and see if I could finagle it back in the lifter bore to avoid pulling the intake manifold, but I don't have any experience like that so it's questionable whether it would work or not
08-22-2016, 09:56 AM | #5 |
The Older Generation
If you could find someone with a bore scope or automotive inspection camera you could insert it into the pushrod hole to see where it is at.... LockDoc
08-22-2016, 09:58 AM | #6 |
Agh, what wicked webs we weave when we have the need for speed ! I wonder if you can get a discount on intake gaskets by the dozen ? Haha , Having fun yet ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-22-2016, 10:38 AM | #7 |
08-22-2016, 10:40 AM | #8 | |
Now I'm wondering if there are better polylocks though. These Comp ones seemed to strip out easily. |
08-22-2016, 11:12 AM | #9 |
Is it 8 foot pounds of torque or inch pounds? I understand the studs must be flat on top for the polylocks to stay tight.
1970 C10 Short Stepper with 71/72 front clip. |
08-22-2016, 02:32 PM | #10 |
I used to buy those intake gaskets, sets of 10 for about $4 each, there was a chevy parts supplier from one of the hot rod magazine ads, you could get mcchord or felpro, came in a plastic bag without the box, good gaskets.
08-22-2016, 04:28 PM | #11 |
The Edelbrock gaskets work great, it's the polylocks that are failing.
08-22-2016, 04:29 PM | #12 |
08-22-2016, 04:30 PM | #13 |
Anybody know of a tool with a magnet on the end I could fish the lifter back into the bore with?
08-22-2016, 04:46 PM | #14 |
Not sure about the poly locks (are they plastic?) and it has been about 10 years since I have worked on locks. When I used play around with that kind of stuff I would put blue Loctite on the allen screw for a little extra protection. I would also take a wrench and wiggle the wrench while I tighten the screw. Never torqued them just kind of guessed and never had one loosen up.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
08-22-2016, 05:37 PM | #15 |
I had one similar to this, just not sure if the magnet will be strong enough. Take an old lifter when shopping to make sure it will pick it up easily.
http://www.homedepot.com/p/Lisle-Min...g&gclsrc=aw.ds
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
08-22-2016, 05:56 PM | #16 | |
08-22-2016, 06:56 PM | #17 |
Fix it til ya brake it Matt! We know you can! Root'n for ya.
I think a group vote should be taken. I vote Matt has to wear a video cam every time he picks up a wrench.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
08-22-2016, 08:10 PM | #18 | |
PS I "fixed" that old 280H hydraulic cam with a big ole custom ground solid one, bout 10 more degrees of duration and it's on a very street unfriendly 106 LSA, I love it, but don't tell GrumpyOldMan OR Gasoline71 cuz I'll never hear the end of it. Last edited by Mrturner1; 08-22-2016 at 08:16 PM. |
08-22-2016, 08:56 PM | #19 | |
it's like it's talking to you.
08-22-2016, 09:51 PM | #20 |
I broke the cam in last week, drove around a bit after resetting lash, then checked again and it needed tightened, and while I was tightened a few of the Allen nuts that go in the top of the polylocks I was thinking "man that feels like it's on the verge of bein stripped out, maybe I should hold off and order a new set......" but that's NEVER happened lol wait? no way it needs to run now
08-23-2016, 01:23 AM | #21 | |
08-23-2016, 02:52 AM | #22 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Put the valve covers or oil deflectors on and run her up to 2000 rpm to refill the lifter. Set screws for poly locks torque down in ft/lbs. If those Comp Cam poly locks failed and stripped out at 8 in/lbs I'd send them back. 12 in/lbs = 1 ft/lb... ~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
08-23-2016, 06:48 AM | #23 | |
OMG ! Your next new thread will be " New cam Thrashed my engine !" or " Is this normal ?" insert picture of rod thru block . I vote for the "Matt wrenching camera ! Posted via Mobile Device
08-23-2016, 12:28 PM | #24 |
Man I really hope you're right! I'll know after work today
08-23-2016, 04:04 PM | #25 | ||
Matt, did the threads in the lock give or the threads on the set screw? I run the Comp Cams poly locks on mine too and they always feel secure. They don't need much. You musta He-manned them down thinking that monster cam was going to fling the push rods right out the valve covers!
